Results 1 to 6 of 6
- Jan 2010
- 28
January 20th, 2010 03:44 PM #1Good day mga bossing!
Paano mo malalaman na ang alternator is undercharging?
Meron bang aparato or tester na ginagamit ang mga electricians to know if the alternator is undercharging? Pwede ba maging cause ang carbon brushers aside sa IC?
Pwede rin ba maging cause na tumaas temperature or mag overheat due to continuous run ng aircon compressor dahil sa insufficient supply ng kuryente coming from the alternator?
Any suggested repair shop ng alternator near Sta. Rosa, Laguna? Or surplus shop na nagbebenta nito within laguna? I've tried to contact Nagano surplus shop pero wala sila binebentang alternators. Sana ung mura lang.
THE AUTO SPECIALIST
- Mar 2006
- 607
January 21st, 2010 12:43 AM #2karamihan trouble sa 96-99 alternators yung voltage regulator ,kaya pag binuksan na yan check na rin yung stator ,brushes and field coil.pati na rin yung rectifier assy .kung minsan palit bearings na rin,
at idle no load a least 14.5v
at idle full loads at least 13.5v
at 2500 rpm no load max 14.8 v
yun ang typical readings na sinusunod ko .these can be done by using a digital voltmeter.
- Jun 2009
- 325
January 21st, 2010 03:13 PM #3The best way to check the charging system of a car aside from voltmeter is by using battery/ alternator tester wherein you could monitor the condition of rectifier/diode, IC regulator and charging voltage. Once the trouble is pinpointed, try to source for parts that needs replacement. In my experience, once the stator, rotor is defective, the best way is to replace the whole alternator itself since rewinding these components will not give satisfactory results (insufficient voltage and current). The best equipment I've used so far in diagnosing charging system is Snap On Microvat wherein it will diagnose what component is defective just by plugging the leads on battery terminals.
- Jan 2010
- 28
January 21st, 2010 08:15 PM #4
THE AUTO SPECIALIST
- Mar 2006
- 607
January 22nd, 2010 01:45 AM #5
- Jan 2010
- 28
January 22nd, 2010 11:00 AM #6Meron ba kayong recommended repair shop ng alternators here in sta. rosa, laguna? Sana ung mura maningil.
At the expense of rear cargo space. The floor is raised around 8inches for the batteries.
2021 Toyota Land Cruiser LC300
