Results 1 to 4 of 4
- Jul 2009
- 7
August 12th, 2014 07:01 PM #1Mga sir's need your help,my dim light and wiper switch suddenly stop working.
Na test na namin high beam ok and when rocking the light switch minsan nagwork dim. For the wiper hindi na talaga nagwork.
Recommend naman kayo reliable auto electrical sa mindanao ave.
Thanks
- 54,290
August 12th, 2014 07:09 PM #2try to inspect the fusebox first. it might be just busted fuse.. consult the car manual..
if you are a little car-savvy, you can check the headlight bulb. the low beam filament might be busted. sometimes, you do not even need testing instrument. simply looking into the filament will show you...
as to the wiper, sometimes the wiper motor is ok. but the wiper mechanism disconnected. if you can hear or detect the wiper motor working, then it must be disconnected wiper lever. (now, that! ... is not an easy repair job to do..)
good luck.
- Jul 2009
- 7
August 15th, 2014 11:52 AM #3Finally my wiper and dim light problem was restored yesterday sa Bigboy/btech auto shop along mindanao ave.
For wiper issue they've found electrical line going to the switch is busted. Works now after replacing electrical line.
Second dim light, after doing various tests on fuse and switch they located the problem on the grounding line going to the bulb holder. Reconnecting the wire solves the problem.
Total damage: P800
- Jul 2009
- 7
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
