Results 1 to 7 of 7
- Dec 2006
- 59
December 6th, 2008 10:51 PM #1mga bossing patulong naman kasi pinatignan ko yung kotse namin (1993 lancer glxi matic) sabi sa sa casa kailangan daw palitan yung distributor kasi mahina daw ang hatak ng kotse. 42k ang presyo! pero may nakausap ako sabi pwede naman daw ako bumili sa labas tapos sa kanila na lang ipagawa. may idea ba kayo kung magkano price nito? saan ok bumili at ano brand ang dapat bilihin? isa pang tanong ko ay pwede ko pa ba ibyahe ang oto ko? kasi sabi posible daw na itirik ako nito kasi nga mahina ang hatak/power. marami salamat!
December 7th, 2008 12:30 AM #2
Wow some people should not be under the hood of a car. A distributor is a piece of metal with a gear attached to the end of it that spins off of the camshaft. It turns a shaft within the distributors housing which has a rotor connected to the opposite end if it, and depending on the position of the rotor in correlation to the distributor CAP it fires the appropriate cylinder. Note that a rotor, and a distributor cap are not a distributor but rather parts that are attached to the distributor. There is also depending on the vehicle a pickup sensor under the rotor, and and on some an ignition module. As far as your question about losing power, the year make, model, engine size, whether its fuel injected, a TBI unit, or carburated is needed to make an educated guess at your problem. Yes distributors do wear out, the shaft in the housing will wear out one day, but would take many many years to do this. All of the parts on a distributor are replaceable unless the housing or the shaft are bent/ tweaked etc.
Generally, the part that wears is the bearing on the shaft. When that becomes worn, the ignition timing develops a "jitter" -- the timing varies too much with time. The problem is visible on an ignition analyzer, and may be how that Casa mechanic made that diagnosis.
If you can remove the distributor cap and rotor, you can physically check it by grabbing the top of the shaft and pushing it from side-to-side or front-to-back. If it jiggles noticeably, it may be worn enough to make the timing somewhat inaccurate.
Whether or not that slop would be enough to make it fail the power in your Lancer is debateable - it would probably have to be very bad to do that, and be a contact-points style ignition. If the car is new enough to have a Hall-effect switch instead of points, I'd probably suspect something else, like timing or a maybe even something simple like a severely clogged air-filter not a 42 thousand bucks. C,mon wake up. Hope this help
- Jan 2008
- 4,726
December 7th, 2008 12:46 AM #3pa check mo muna sa iba... since A/T yan its also a factor para sa mahina hatak...
THE AUTO SPECIALIST
- Mar 2006
- 607
December 7th, 2008 08:28 AM #4kuha muna ng second opinion
baka hindi naman distributor yan ( sobrang mahal yata yan )
- Dec 2006
- 59
December 7th, 2008 09:47 AM #5salamat sa mga nag reply! patignan ka na lang muna sa iba. meron ba kayo ma recomend na reliable shops las pinas/cavite area?
December 7th, 2008 09:57 AM #6
December 7th, 2008 01:43 PM #7
hmm. ang mahal naman ata ng distributor na yan. Looking at it, i guess the price would be around 3-5k lang.
Daming issue ng SU7:grin:
Xiaomi E-Car
