Results 1 to 3 of 3
    Oct 2011
    My cousin pregio's alternator was heating up is it normal?We had change the carbon brush and all the bearings. but still it is heating up. We tested voltage and it is now charging(13.6 V UP) as the engines run.
    well.. it is beside the engine and behind the fan's hot air path.. is it really heating up, or is it being heated up by the engine and the fan's hot air?
    and how hot does it get? warm.. comfortably hot.. uncomfortably hot.. scalding hot..?
    Feb 2009
    Quote Originally Posted by Aracad665 View Post
    it is normal for it to get hot. the current flowing to the field coil and the current flowing out of the stator windings make up most of the heat. that is why, the fan is either integrated into the pulley end of the shaft or in newer delco remy alternators the fan is inside the housing on the carbon brush end. as long as you have the right fan blade rotation, it should be okay.
Help on Pregio's alternator
