Results 1 to 12 of 12
  1. #1
    guys tama ba yung ginawa ko sa rear foglight?
    OK > umiilaw siya pagtinapakan ko yung break (off parklight / headlight) daylight
    ERROR > umiilaw siya habang naka on yung parklight / headlight
    pero namamatay siya kapag tinapakan ko yung brakes, diba dapat mag ddim lang rin siya
    May 2011
    ano ba gusto mo mangyari?
    sabay sa preno o sabay sa parklights?
    yun rear fogs mo double contact din? Kasi sa drawing mo 2 lines ang + e?
    Jul 2003
    Rear fog light normally have a different on/off switch to turn it on. If it is dual filament type, the hi-wattage side should be
    driven by the brake light circuit. How to do that? You may need some relay/contactor for proper operation.
  4. #4
    Quote Originally Posted by skybison View Post
    nakalagay po sa itaas yung mga nangyayari.. sumasabay siya sa preno kapag naka off yung parklight.. kapag bukas naman yung park light sympre bukas rin siya pero pag nag preno ako nag ooff hindi nag ddim..
    oo double contact yung bulb..
    Jan 2009
    Please be clear with what you want. Are you planning to put a 3rd (or 4th) brake light or a rear fog light? They serve totally different functions.
  6. #6
    rear fog light lang po.. ang rear foglight ba hindi nag ddim, steady light lang?
    Quote Originally Posted by cokezero View Post
    steady lang dapat. and dapat may switch ka. wag naka-ON parati. kawawa naman kami at masisilaw kami.
    Oct 2009
    Your concept of tapping it sa rear parklight wire is wrong. Instead tap it sa plate number lights, pero dapat ay relay switch ang nakatap, then you run another wire directly from the battery positive to the relay and from the relay to the rear fog. This way, the relay will be the "switch" being triggered by the plate number light (which also lights up pagnaka on ang parklight) and the power that powers up the bulb ng foglight is directly from the battery and not sharing the power needs of the platenumber lights.
    Kaya nag-ooff ang rear mo kasi the wiring of the two filment bulb brake and parklight combo turns off the parklight pag nag brake ka. This is probably a new thing about wirings ng oto mo, kasi as far as i know hindi ganyan ang normal wiring ng typical parklight.
wrong rear fog light installation?
