Results 1 to 8 of 8
- Jan 2008
- 4,726
October 7th, 2019 07:29 PM #2
October 8th, 2019 12:05 AM #3
How to Wire an Illuminated Rocker Switch
- May 2011
- 481
October 8th, 2019 05:16 AM #4
October 8th, 2019 08:23 AM #5
- Nov 2009
- 3,509
October 8th, 2019 08:43 AM #6The divider on the terminal block is a dead give away-same row is the switched terminal while opposite row is the return terminal for the light. Most AC rocker-switch uses neon lamps, while DC rockers uses incandescent or LED which the switched side is usually the positive/anode.
- Oct 2009
- 2,271
October 8th, 2019 04:34 PM #8
There ought to be markings on the side like voltage and current limits (including the specs of the bulb inside)... or even the full schematic of the switch.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
