Results 1 to 8 of 8
    Wiring diagram of a 3-pin switch with light indicator ...
    Thanks!
    Jan 2008
    Quote Originally Posted by jjmd3_787 View Post
    Thanks!
    Wala ba sa side? Test mo muna kung alin yung open side..
    Sep 2004
    How to Wire an Illuminated Rocker Switch
    May 2011
    Thanks!
    One is terminal 30 or power, one is ground for the illuminated rocker and the third one is 87 or load side.
    Wala pong markings or any signs. Yung brand name lang at power ratings. May napanood ako sa YouTube pero nakahilera yung terminals. Hindi po tulad ng nabili ko na 2 rows.
    The divider on the terminal block is a dead give away-same row is the switched terminal while opposite row is the return terminal for the light. Most AC rocker-switch uses neon lamps, while DC rockers uses incandescent or LED which the switched side is usually the positive/anode.
    Oct 2009
    ung single terminal ground switching naman ung 2 terminal sa + lines
    Jan 2009
    There ought to be markings on the side like voltage and current limits (including the specs of the bulb inside)... or even the full schematic of the switch.
Help! 3-pin switch wiring diagram ...
