Originally Posted by
mina_nuka
If your situation for low visibility is that your headlight lenses are oxidized or hazed, clean or replace the headlight assembly. This problem was not a concern when cars used sealed beam headlights with glass lenses. There is a limit as to how bright your lights are without inconveniencing the oncoming driver. If your situation is that you have inadequate night vision, use driving glasses to be able to see better. Don't be a dick to other drivers on the road. Share the roads, they are not yours nor it is your right to drive. The reason driver's license are issued is because it is a privilege, not a right. Otherwise, in the same token, if breathing was a privilege, you'd be required a license to breathe.
How about 97 LXi?
Civic horsepower
