Results 1 to 7 of 7
    Aug 2006
    good day mga fellow tsikoters at mga gurus..
    i just recently chagne my engine from 16valve na carbs to 4age silvertop, 1 week ko siya na gamit...ok naman siya...hatak idling, aircon...pero after that bigla nalang namamatay yung makina pag hinde tinapakan yung gas..
    pag tinapakan konaman yung gas at pinatakbo ko...kumakadyot siya, parang nalulunod..
    any advise mga peeps kung ano sira nito at ano mga possible steps na gagawin ko para maayos to..
    following TS done:
    1. Changed Sparkplug
    2. Changed fuel filter
    3. Changed different distributor
    4. Changed different computer box
    5. Changed hightension wire
    6. Check all wirings ok naman daw...
    7. Changed ignition coil
    8. Changed airflow system (with map sensor)
    ano kaya problema nun...any inputs will be grealy appreciated..
    Aug 2004
    Hindi ba MAF yung silver, hindi MAP? Or are you using the box and MAP off of a blacktop?
    Dec 2007
    hey bro, pls have the TPS (Throttle Position Sensor) checked first before doing anything else.
    also, nangyari ba yung problem before or after nung nagpa "Tune-Up" ka??
    also * Niky, Im pretty sure na naka MAP sensor ang both Silver and Black top 4AGE 20 valve. (well.. thats what I get if I order these engines from Japan.. ewan ko lang kung ano ang binebenta sa Pilipinas.)
    aite, peace.
    Aug 2004
    I'm not sure, myself. Alam ko yung MAP is the reason that the blacktop has more potential, but I'm not a Toyota guy myself. ;)
    fuel pump?
    Aug 2006
    ok na menor ng oto ko...
    Sensor ng TPS ang culprit...hehehe
    pinalitan ng ibang sensor..ayun ok na ok na..
    thank you sa lahat...
    May 2007
    may adjustment yang tps d basta kalas kabit yan..
Idling problem with my 4AGE silvertop
