Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    papakabit kasi ako ng relay sa headlight. sa wizard parang over price labor nila is 700 daw. may marerecommend ba kayo na cheaper and magaling din? ty.
    IMO, if this will include the wiring, OK na since Wizzard is a reputable electrical shop AFAIK... One thing i've experienced over the years with placing relays in our cars is that "i get what i pay for" :confused: ... its a really big hassle IMO as i end up spending more in the long run and i've experienced getting loosing my headlights at the most inopportune times (i.e. late at night in Zambales) because of a bad install.
    I have mine done at Reys Electrical and i spend 1.6K for the wires, relays, relay sockets, and Bosch ceramic socket. A bit expensive when compared to others but the work is very good (soldered connections, color-coded thick wires, etc...).
    700 pesos for a headlight wiring upgrade? kumpleto with the relays and wires? mura na yan....
    Vinj, where is Rey's elect. located? Alam nyo ho ba ang phone num.?
    Hboy, 700 is labor only daw.
    mas maganda ba yang headlight relay/upgrade kaysa
    magpakabit ng spotlight/foglights??
    medyo malabo na rin itong ilaw ng car ko kc.
    teka... sa kanila ka rin ba bibili ng harness o gamit mo?? 700 pesos for labor is quite expensive... bumili ka sa hans tool sa shangrila or dun sa bosch shop dun ng headlight wiring upgrade kit... may instructions dun to do it DIY.
    yes. labor daw sa wizard for pajero is 700. gulat nga ako eh.
    May na-refer sa akin pinsan ko who has an auto supply. Dito sa may P.Tuazon before reaching Chrome Dazzler, Johnny's auto-elect. Bahay lang ito medyo luma pero may maliit na garage, magaling daw dito, kasi lahat ng cars nila dito sila nagpapa-relay ng headlight saka kung anu-ano pang electrical job.
    Kahit lumang kotse kaya daw , kasi yung Camarro nila pina-complete re-wiring nila ok naman daw.
    Labor sa Pajero ko is 280 lang daw both headlights na, saka soldered connections din sila sa wiring.
    Sep 2013
    Quote Originally Posted by CZintrclr View Post
    Sir may number ka ba ni Johny Electrical?
    Feb 2013
    Quote Originally Posted by Madmaxx143 View Post
    Sir, the last login from CZintrclr was February 2009.
    Check always in the profil the last login, so you know is this member still active.
    Yung Rey's maraming branch yan. :D
    Jun 2003
    makikisingit na rin ako ng tanong...related naman sa wiring harness and relays; plan ko rin kasi mag taas ng wattage ng bulbs plastic ang lens ng gen 2 l200 ko hindi kaya sya mangitim pag mataas na wattage ang gagamitin?
    sheesh.700 for labor!?!?!?
    dang....i know a shop thats cheaper.a lot cheaper.
    herhehrehrehrher
    grabe naman un....
    ang dami na naming nakabitan niyan...and magkano labor!?ask ronald nalang.
    9218831.call nalang kayo.i dont know if tumatanggap pa siya ng trabahong ganyan.
    but most likely.call for more info.thanks.tell him you are from tsikot.
    sheep.may possibility na umitim talaga yan.plastic eh tapos kabitan mo ng 90/100 watts na ilaw....talagang ganun.kahit naman ung glass lens umiitim din.
    Jun 2003
    thanks i guess ill stick to my stock bulbs
    I have mine done at Reys Electrical and i spend 1.6K for the wires, relays, relay sockets, and Bosch ceramic socket..
    Mag pinsan ang founder ng Wizzard at Rey's... hehe... kaya parehas ang "design" ng shop... tage Nueva Ecija sila pareho... Wizzard ako lagi pagawa... kababata ko anak ng mayari eh hehe... Been going there since 84...
    As for the cost... nagpakabit ako sa Wizzard ng Flosser 90/100W lights, including bulb, sockets, relays and labor mga 1000 inabot.
    Jan 2003
    reys has a branch in marikina n cubao. nsa directory yung number nila
    theveed, I just called up wizard, siguro tumaas price nila ngayon kasi labor lang daw 680. Pag kasama wires, socket and relay 1400 total cost.
    If you are in the Sampaloc/Espana area, I suggest TOWER OF DAVID. Corner of Maceda and Espana Sts. Ungas can vouch for this.
    wire_tap, lapit lang sa akin yan ah. alam mo ba telephone num. nila? ty.
    Jun 2003
    hanapin mo na lang yung pares sa may espana kahilera lang yun dun you wount miss it
    Natawagan ko na. Would you believe it, 150 lang daw labor nila for the relay of both headlights??? Sir Ungas and Wire_tap, parang sobrang mura naman yata dito, nasubukan nyo n ba magpagawa sa kanila? ok ba? ty.
looking for a good auto-electrical shop
