Results 1 to 7 of 7
- Jul 2016
- 44
September 23rd, 2016 07:06 PM #1
- Oct 2009
- 2,271
September 23rd, 2016 07:18 PM #2hindi normal yan.umiinit nga yang mga yan pero hindi sobrang init na halos hindi mo na mahawakan.
maaring may loose connection.or grounded.short circuit.gano ba kabilis mag init yan fuse box mo?
- Jul 2016
- 44
September 23rd, 2016 10:58 PM #3
- Oct 2009
- 2,271
September 25th, 2016 07:47 PM #4
- Mar 2013
- 220
September 25th, 2016 08:36 PM #5Engine wash... Grounded... Cel na....
Pwede check your auxfan radiator and aircon fan baka flooded ang motor natutukan masyado ng pressure washer.
CEL pwede oxygen sensor natutukan din nghusto kaya grounded, try compressed air ng mawala moisture then reset ecu. Baka sakali makatulong lang sir.
- Mar 2013
- 220
September 25th, 2016 08:46 PM #6Maganda jan malocate kung anong relay ang nagiinit, pwedeng isaisa tanggalin mo muna hangang (tanggal kabit ba) para locate kung alin, from ther madali na.
Kung may srs at abs ka makita na relay ay wagmabunot CEL ka kagad malamang hehe
Typical relays ang man jan horn, aircon fan, rad fan, headlyts, parklyt, evap fan, kung ano nkalagay sa guide jan. Skip m lang starter n ecu relay. Check also mga relays baka maytubig sa loob. Bka masyado magaling ung naglinis hehe
September 26th, 2016 09:39 AM #7
disconnect the battery
disconnect the harnesses going to and out of the fuse box
spray electrical contact cleaner and let dry
spray water displacer (WD) 40 and reinstall
observe while running the engine. if you have access to an infra red thermometer, observe the temperature before and after this procedure to note the difference in operating temperatureLast edited by jick.cejoco; September 26th, 2016 at 09:48 AM.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
