Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Sep 2005
    Sirs, the fog lights of my Innova is H16 12V 19 watts. H16 bulbs are very rare, can I use H11 12V 55watts instead? Is there any danger? BTW the sockets of H11 and H16 are the same. Fit na fit sya sa housing. Thanks
    Quote Originally Posted by ufl784 View Post
    Up for this, Ill be doing the same thing but for my vios naman po, thanks sa mkkasagot
    Jun 2012
    H16 is normally for Ford. The H16 in Toyota foglamps are actually H11 base.
    The PGJ19 base series common with H8, H9, and H11. Osram used H16 for their 19W bulb of this series.
    Quote Originally Posted by confused shoes View Post
    Thank God for an answer sir, so is it safe to assume that using h11 on foglamps in toyota is safe? I mean, even thought they have different wattage as stated
    Since mas mataas ang wattage ng H11, baka di kayanin ng original harness. Baka need mo ng harness kit with relay. If gagastos ka lang din for harness kit and relay, better na rin to settle for 3000K or 4300K H11 HID
    Sent from my LT26i using Tapatalk 2
    Exactly what I had in mind, naisip ko din na mapapagastos, then go na lang din sa H11 HID para mas maganda na talaga, thank you sir
    Aug 2012
    wala bang H16, 19W bulb sa Toyota casa? hindi naman siguro kamahalan kung bulbs lang, less hassle pa. Fog light color temperature is normally 2600K to 2800K. this gives best results. HID for fog lights are useless.
    Our 2008 Innova is using 51W foglights H11,- all stock.
    “The measure of a man is what he does with power – LJIOHF!”
    Duterte for President of the Philippines in 2016!
    25.1K:dog2:
    Aug 2012
    *TS: there you go, problem solved. use 51W, H11 instead or even 55W should be no issue.
    Ano nga kaya meron sa Toyota at puro H16 na fog lamp bulbs nila? It's useless eh ang dilim. Pati Innova pala at Super Grandia na dati naka H11, naka H16 na rin.
    In my experience ok naman 3000K sa fogs..
    thanks guys, plano ko kasing gumamit ng osram fogbreaker h11 sa fogs, since nag palit na ko ng headlights to nightbreaker, para mas maganda yung combination.
    Jun 2012
    ^ Check mo yung haba ng FB. Kung mas mahaba kesa yung stock na H16, magiging sabog yan.
    Apr 2008
    Kung H16 and 19W lang ang stock bulb specs (halogen), ok lang ba palitan ng H11 30W (LED)? Fit naman siya ang concern lang is higher wattage, but LED na
    Quote Originally Posted by huzky View Post
    i have the same plans as you are.... watching this thread.
    Aug 2012
    See page 1. Somebody already replaced stock H16 19W bulb with H11 51W bulb. Your H11 30W should be no problem. Does not matter if halogen or LED.
    Sent from my D5833 using Tapatalk
    Apr 2012
    Had a weird problem with my vios regarding this H16 bulb.
    Stocks are originally H16. When the time it conks out i ordered H16 to my friend na may auto accessories shop. He told me na H11 ipapalit kasi fit din daw. To cut the story di pumapasok ang H11 we tried it sa binebenta nya na after market na fog light para sa vios pumapasok H11 dun sa bahay ng aftermarket. Pasok na pasok. When we tried to put the H16 from aftermarket to my orm fog light, ayaw pumasok ng bulb kahit H16. I find it weird. Kaya nag bawal ng sides na metal sa H11 para lang pumasok sa akin
    Sent from my LG-H818 using Tapatalk
    i was surprised when i surfed the internet.. even manufacturers have package labeling issues! one popular brand had problems, interchanging H11 and H16 on the label ,,,
    Apr 2008
    So if you compare the 19W halogen vs 30W LED, mas higher consumption pa din talaga yung 30W kahit LED pa siya?
    Also, tried comparing H16 and H11 side by side, mas mahaba yung H11.. But they both fit exactly
    Nov 2015
    Quote Originally Posted by mykc View Post
    H11 and H16 both are the same size but not the same wattage, H11 55w while H16 19w, it is not also advisable to use H11 on a H16 oem because the rating of the stock wire harness may not carry the 55w. Or worst come to worst the h16 projector might melt.
    Sent from my iPhone6s using Tapatalk
    Aug 2005
    Quote Originally Posted by ikloyputograpi View Post
    Using LED 30W H11 for H 16 19 W Fog Light wont be a Problem since LEDs has lower operating Temp compared to Halogen Bulbs
H11 and H16 Fog Lights Bulb
