Results 1 to 10 of 10
    Guys maitnaong ko lang, may nagsabi sa akin na para matignan kung malakas pa ung battery mo is kelangan ishort ung battery, i mean ang ginawa ko is nagkabit ako ng booster cable tapos shinort ko, yellow ang spark, anu ibig sabihin nun? ang sabi sakin pag silver ang spark malakas pa ang battery, is this true??
    Aug 2005
    Quote Originally Posted by X-isle View Post
    pwde rin pero manghuhula ka prin sa ganyan, the best way to check ur battery without VOM or battery tester is for the first time na magloko battery mo:
    1) remove cap of all battery 6 holes then turn ON all lights even hazard lyts, wiper, aircon then someone crank the engine while u look at the battery holes pag may bumula un ang may sira na plates, isang butas lang ang may bumula you have to replace the battery at dinatatagal un.
    2) pwde rin ung cnabi mo na sshort m ung + and - terminal at tingnan mo kung maybubula na butas (remove mo lang battery terminal 1st baka macra ECU and alternator macc mo pa ko hehehe) carefull lang sa pagshort pagnapatagal ka pwde pumutok or sumirit ung acid yari ang mata mo
    pagmaintenance free battery eh wait n see k n lang, u need load tester talaga wlang butas na para makita eh.
    Jun 2006
    safest and best way to check a battery is with a Volt Ohm Meter also called multi meter. Click on the link ofr detailed instructions.
    http://www.repairfaq.org/ELE/F_Car_B...CARBATTERY_006
    Jun 2007
    makisakay nako dito mga sirs
    ok din ba I check ang battery using yung mga battery tester
    na plug sa cigarette lighter jack? curious lang po TIA
    san ba maganda bumili ng car battery na makakamura? any suggestions? like sa banawe ba mura battery dun? TIA
    Try Motolite sa Congressional Ave -- beside Colegio De San Lorenzo. Barkada ko nung gradeschool may ari nun. Mura sa kanila, nagpapakilala kasi ako pag bumibili ng battery. Alam kong rate nila ngayon 2.5k
    Feb 2005
    try to test also the car battery after traveling some kilometers and when the engine bay is hot.
    mine is normal and gives the right amount of V when cold, but when the engine bay is already hot and the acc's turned on, that's where the problem starts.
    pag namatayan ka tapos try mo mag-start uli, hirap mag-crank ng engine yung starter. After a week, the battery failed. Di na talaga nag-start kahit malamig pa yung battery.
    just go to the nearest battery shop, libre naman pa test kung malakas o mahina na battery mo, cgurado ka pa
    Just have the battery tested sa battery shop....
    3303:shocked:
    Quote Originally Posted by cocoy_01 View Post
    yup cocoy, i tried it after ma read yung thread mo a couple of days ago, i was from cavite pauwi manila, pag dating ko ng bahay pinatay ko na ung engine tapos mga 5 seconds after try ko start ang narinig ko lang sinabi ng makina "click", tapos try ko ulit, nagredondo, tapos try ko ulit nagstart na, ayun, baka pag dumating ang time na magpapagas ako from a long trip, eh diba pinapapatay nila ung engine ng sasakyan, naku baka matirik ako ng di oras, what do you think is the solution, pareho na din ba sau na palit na ung battery? d ko kasi alam kung gano na katagal batt ko kasi kinuha ko yun sa sasakyan ng erpats ko matapos ako mastranded dahil bumigay ung dati kong batt...
About car battery is this true??
