Results 1 to 6 of 6
    hello mga bossing, Baguhan lng po ako dito.. me tanong po sana ako, Ano kaya ang depirensya ng makina sang sasakyan ko kse everytime mag tune up ako at mag change ng spark plugs ang daming oil na nag stuck sa sparkplugs ko. ano kaya ang deperensya? btw, yung engine ko 2E Series ng 1990 Toyota Corolla. salamat po.
    Feb 2006
    maybe some broken oil seal rings of the piston.
    Quote Originally Posted by JMV View Post
    anong dpat bang gawin? kelangan ko bang i top overhaul? salamat !
    May 2005
    or could be valve seals, overhaul will be the solution.
    this should be in the workshop forum
    Jun 2004
    plugs could be the wrong type or heat range for your car, baka wala rin sa timing or running rich yung engine
    You need to change your oil seals. Tumatagas na kaya nagkakalangis ang sparkplugs
spark Plugs..
