Results 1 to 14 of 14
    Feb 2009
    in most of general motors, i.e. Cadillac,Chevrolet,Buick, Oldsmobile, Pontiac and GMC, discourages technicians from poking into the wire insulation to make measurements or continuity because it breaks the wire insulation and therfore becomes a conduit for moisture that causes "ghost" problems. motorage discourages technicians from backprobing terminals because it can "mask" a potential cause of electrical anomalies or problems. it could "accidentally fix" a problem and could be a potential backjob. the question now is, which method do you prefer in wiring diagnostics?
    personally, if i have access to the wring, i pierce the insulation to make measurements or diagnoses. the question now is: how about the wire insulation injury?
    with this, i use liquid electrical tape after the testing to seal off the wire insulation injury. in the absence of liquid electrical tape, i use acrylic nail polish to seal off and prevent water intrusion into the wires. afterall, the most sensitive wires are the ones that lead to control modules. which, in most cases, a very confused and uncertain technician let alone a "mechanic" always blames the computer.
    Feb 2009
    With today's cars that have a myriad of microcomputers on board, it is risky to disconnect the battery to check the function of the charging system. the high voltage spike/surge can cause trouble to the sensitive electronics. never disconnect the battery terminals with the ignition switch in the ON position.
    How about when charging the car's battery using ctek and the like? How safe is it really?
    Sent from my RMX3690 using Tsikot Forums mobile app
    I always charge the battery with engine off, doors locked & hood switch jammed. It may take longer to charge if unlocked, anyway the BCM will shut-off after several minutes of idle state. Charger could pump up to 17Volts esp when desulfating mode.
    Jan 2009
    The battery should be disconnected from the vehicle when running any desulfation/repair modes. Some chargers are smart enough to disable this mode if it senses the vehicle electronics. Others will have a warning label discouraging the use of this mode while the battery is still connected to the vehicle.
    Then you will have to use another tool to avoid losing car electronics memory, or it may cause check engine light if the sensors are sensitive enough to detect delays in low voltages triggering a false alarm.
    No harm done to all the vehicles I've charged with the 7-stage charger that comes built in automatic desulfator.
    Jan 2009
    I don't think those chargers defaults to desulfation anyway, unless the charger logic deemed it necessary after assessing the battery's health. On some chargers, this mode must be triggered manually.
    When I worked on one of the headlights in my car, I needed to remove the battery to gain better access. I used a discarded 12V UPS battery connected in parallel before disconnecting the starter battery. That way, the system never lost power. Putting it back is simply the reverse.... I only took out the UPS battery after the starter batter was back in-circuit. This is a good alternate use of a jump pack if you have one.
    Jan 2008
    agree.. in my ctek charger, desulfation mode voltage is at 15V, which maybe too high to modern electronics running at 14.5volts
    Mar 2004
    Have run CTek desulfation mode several times with battery connected ...
    Feb 2009
    some toyota cars of the 90s, the system voltage can go as high as 15.1 volts without damage to the systems. the keep alive memory (KAM) such as electronic tuned radio, pcm memory, body control module memory, immobilizer , can be kept by using a memory saver conndcted either to the DLC3 or to the BAT of the alternator with a 12 volt battery. doing this, the doors closed, all swiltches turned off.
    Jan 2009
    This is the warning from Noco when using battery repair mode.
    NOTE: USE THIS MODE WITH CARE. THIS MODE IS FOR 12-VOLT LEAD-ACID BATTERIES ONLY. THIS MODE USES A HIGH CHARGING VOLTAGE AND MAY CAUSE SOME WATER LOSS IN WET (FLOODED) CELL BATTERIES. BE ADVISED, SOME BATTERIES AND ELECTRONICS MAY BE SENSITIVE TO HIGH CHARGING VOLTAGES. TO MINIMIZE RISKS TO ELECTRONICS, DISCONNECT THE BATTERY BEFORE USING THIS MODE.
    Considering how many computers and other electronics a typical vehicle has onboard nowadays and how much each can fetch you if and when they get damaged, I personally wouldn't risk it. But it's you're car so it's really up to you if you think the odds are with you.
    I replaced a Tucson and Ranger battery afterwards it had a CEL w/c I have to flush using an OBD scanner. From then, I always use the OBD port pin# 16to inject an external 12VDC whenever I replace a battery.
    I even jump-started an innova using 6Ah Makita 18V battery, no probs whatsover. The starter could operate from as low as 7V to 24V, the electronics are much the same with built in filters to tolerate the wide voltage range.These automotive electronics are designed to handle double its voltage arnd 24 volts, higher than that like voltage spike more than 24V like due to a busted Alternator regulator then its a fried electronics.
    My 7-stage charger with its 1st stage as desulfator-works by injecting around 17V and high frequency to remove the sulfates accumulated in the plates, i could even see and hear the inside of the battery boiling during this process. No harm made on the ECU and accessories I just make sure the car is on idle/sleep mode.
    Mar 2004
    No such warning from CTek ...
    Jan 2009
    Ah well. I have only used the repair mode while the battery was disconnected. It just made more sense to me as I work with electronics as one of my hobbies. The thought of a pulsating and relatively elevated DC that's being fed back into the vehicle does not sit well with me.
    Here's something I found elsewhere. Take it with a grain of salt, but I'd rather take the precaution.
    Battery Sitter Myth Busters and Important Facts – BatteryGuy.com Knowledge Base
electrical diagnostic practices/procedures
