Results 1 to 6 of 6
    Help guys! I have a Nissan Patrol and the front left turn signal light is not working. The rear left turn is working but it blinks faster than normal compared to the right turn signal lights. Is there a way to check this by myself? If not, can you suggest a good electrician somewhere here near Eastwood Libis? Will appreciate any help. Thanks!
    Jul 2006
    If the front left signal light is not working and the left rear signal light blinks faster then chances are the bulb is out, replace with a new one and you should be fine. The faster blinking is a common feature to indicate that a bulb has gone bad and needs replacement. On some cars the turn signal will indicate which side is bad so see if your right side blinkers are at their usual rate or have started blinking faster.
    Palitan niyo lang po yung bulb ng left signal light niyo and it will be fixed. Ganyan din po na-experience ko before. Replace the bulb and the blinking rate returned to normal. Good luck.
    ok try ko po. thanks sa mga reply
    Jun 2007
    ayon na nga just replace that busted signal light at balik sa normal yan.
    Apr 2006
    happened to me as well. pag palit ko ok na!
    pero after ilang days lang balik uli sira, busted agad un bulb.
    ano kaya ang sunod na prob?
    thanks
Grounded signal light?
