Results 11 to 16 of 16
- Apr 2008
- 51
May 31st, 2011 06:54 PM #11OBD II ba yang kotse mo? I have an OBD II scanner to read CEL and I live just near Munoz. OBD II has the connected usually under the driver dashboard (honda civic near the center, vios is in front of the drivers seat)
on capacitors, any repair shop can do it...don't notice one on roosevelt/frisco though. depends also on the function of the capacitor. it's just a minor soldering job I can even do it but buy the part yourself (in Munoz near Mercury there are electronics shops)
in raon, one of my favorite haunts, there are also many repair shops (i'm an ECE and electronics used to be my hobby)
May 31st, 2011 08:41 PM #12
sa civic 96 vti, ganyan din yata, pag ignition "on" lahat ng ilaw sa dashboard mag"on" including orange CEL , then after about 5 secs mamamatay na ang CEL , this time doon ko lang start ang makina kasi doon lang natapos ang system power up test,then pagka nakaidle na ang makina dapat remain "off" ang CEL , kung ganito ang situation normal lang ito, but kung iilaw ang CEL then doon merong trouble. parang ganito lang ang nangyayari sa iyo at normal lang ito,
June 1st, 2011 02:23 AM #13
sir I have no idea if obd II ba tong oto ko.. but I have my car diagnose by Car Zone in banawe and they have scanned it from this specific location
wala naman nakitang problema.. now hindi na talaga matangal yung CEL nung ginalaw ng mekaniko.. so problema ko naka stock yung kotse dun... they say it might be main relay or my comnputer box na talaga. wala naman lost and corroded capacitors sa ecu ko naayos na nga pero ganun pa din.. ayaw na matangal ng CEL on second click na supposedly dapat mawala in just 5 -8 seconds lalong nagkaron ng problema.
sir near munoz ka ba?? yung oto ko kasi.. nasa along del monte ave after police station 2. naka stock kotse kasi ayaw mag start dahil ayaw na mawala nung CEL, meron dun mechanic shop yung red na esi akin yun. hindi ko alam if OBD II yung kotse ko.baka sir matulungan nyo ko? pm na lang po tayo mag usap for price... wala din kasing gamit yung mechanic shop na pinag dalan ko mga polpol. hehe.
sir hindi normal yung problema ko... problem ko matagal mawala yung CEL on second click hindi ko naman po sinabi na may CEL ako when engine starts... super delayed lang talaga mawala ng CEL ko. pero tanga tanga na mekaniko pinag dalan ko ginalaw lahat at ngayon ayaw na mawala ng CEL on second click. sigh
- Apr 2008
- 51
June 1st, 2011 06:25 PM #15oh, OBD I...sorry can't help you there.
the CEL lights up during initial ECU boot up and some sort of system self-diagnostics...
but your description of during cold weather doesn't fit your IC/ECU theory that it's bad. some sensors/switch/relay may be getting moist on cold, rainy days thus the intermittent problem. capacitors are designed to tolerate temperatures. how about looking at places that get wet/moist on rainy days?
June 4th, 2011 07:23 PM #16
Guys ok na po kotse ko..
changed computer box: 8k
changed sparkplugs and CTS (coolant temperature sensor): 1.4k
labor :2.5k
Mechanic: G6 banawe.
masakit sa bulsa pero ok na din may sira na din kasi computer box ko kaya ok na din ganda ng takbo.
thanks for helping guys.
another problem I need latero for my mouldings problem.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
