Results 1 to 20 of 32
    Apr 2006
    guys, anyone has done this:
    i want 2 horns.
    1 - for normal use to attract attention
    2 - para sa mga pasaway na tao sa kalsada.
    yung magkaiba sana ng switch/button.
    sorry if it might sound stupid. newbie lang sa cars
    Quote Originally Posted by wewoy_romero View Post
    i want 2 horns.
    nagawa ko na yan dun sa old VW beetle ko. yung isang switch asa ilalim ng dash. ginamit ko ata nun is yung parang button lang ng doorbell buzzer, yung isa normal asa steering wheel.
    Sep 2005
    Or you may use a relay so you may use the horn button on your steering wheel and have a small switch on the dash to choose whether to use Horn A or Horn B.
    Sep 2004
    I've been thinking of adding a second horn, myself. Dami kasing dumededma lang pag nagbubusina ka eh. Balak ko sana, stock + Stebel.
    Pero konting ingat lang. Pag masyado kang 'horny', madali kang mauubusan ng 'energy'.
    Quote Originally Posted by Bogeyman View Post
    ganito set-up ko ngayon. di naman ako naaubusan ng "energy" basta hinay-hinay lang
    Nov 2006
    1 extra relay and fuse.. para walang piyok>..
    Quote Originally Posted by russpogi View Post
    ganito po ang setup ko ngayon...
    stebel magnum and stebel nautilus...
    pero parang useless din eh...
    plan ko na gawing 2 nautilus na sabay nalang...
    same as mine, a hidden switch under the dash as selector.
    horn A - stock Denso high and low
    horn B - 2 Bosch Airmaster
    May 2005
    i want 2 horns.
    pwede iyan ..madami tsikoteers na may set up na ganyan
    ask mo si XTO
    kahit iyon horn button sa steering wheel mo ay pwede na ( di kailangan ng two button , para sa two sets of horn) ,
    gagamit ka lang ng toggle switch ,
    para pag switch mo kung stock horn ang gusto mo gamitin
    or ang para sa mga pasaway horn mo
    Ok lang iyon lahat naman dumadaan sa "newbie"
    wala naman pinanganak na marunong agad
    hanapin ko lang pic/diagram na DL ko dati
    post ko dito later
    i want 2 horns.
    Yung mga bus na assembled by major companies ganyan ang set up ng busina. One for city and one for highway. Kaso yung mga driver kahit nasa city yung highway horn pa din ang gamit.
    Dun sa box ng busina, naka-detail kung paano mag dual horn set up. Naka-drawing iyon dati sa box ng Stebel ko. May switch lang sa dash to select between horns pero yung steering wheel pa din ang pang-trigger.
    Our old Datsun 180B Coupe had a dual horn set up.
    Apr 2006
    thanks mga sir. hintayin ko yung diagram. pero kaya naman siguro yan ng mekaniko gawin. nakakainis na kasi minsan mga nakakasabay sa kalye
    Jul 2006
    i posted this diagram sa www.fordclubph.com ... ganito ang setup ko ngayon
    Quote Originally Posted by JagXtrm View Post
    yan din ang binigay mo sa kin ah minsan daanan namin ni boeing
    snfl mo bro ng ma-testing kabit namin sa xrm n'ya.
    May 2005
    Quote Originally Posted by xto View Post
    Bro , maka drain ang batt ng XRM ko sa lakas ng SNFL ni jag xtrm
    May 2005
    Boss ,
    Question lang po doon sa terminal # 86 kasi dalawa na po sila
    terminal # 87 po ata ang isa dapat na katapat ng terminal # 87A
    na papunta sa (+) ng horn
    i want 2 horns.
    I have a similar setup in my car...
    1 - stebel electric air horn
    2 - stock horn
    I have a selector switch to choose which horn is active. So when I hit the button on the steering wheel, the prefered horn is used. Basically the selector switch activates/deactivates a relay to which horn is prefered.
    Mar 2007
    For stebel nautilus concurrent with stock horn you don't need selector switch. To use stock just tap on your horn for a split second. The nautilus has a slight start up delay thus it won't sound. This is what I do when I don't want to startle people with my nautilus...
    Sep 2004
    hmmm...nice question..nice answer guys.. magawa ko nga eto.
dual horn
