Results 1 to 9 of 9
  1. #1
    guys ano kaya problema nung ilaw ko, napansin ko lang pag naka hazard
    medyo nag bblink rin yung park light ko.
    tska parang sira yung hazard ko kasi minsan nag hhang siya tapos
    magiging okay na ulit
    isuzu ls 1994 pickup
    mukang malas oto mo ah lagi sira? relay yun bili ka hazard relay
  3. #3
    Quote Originally Posted by EE100shiro View Post
    haha matanda na kasi yung pickup sir e ) pinamana lang sa akin kaya ako na nag aayos
    salamat sir cvt & jick
    Aug 2010
    i have almost the same problem. pag hazzard, its the brake lights that blink. pag brake, all lights up. crazy..
    can you recommend a good car electrician pref. within malate or makati area?
    Feb 2009
    Quote Originally Posted by trucker111 View Post
    check your light bulbs. sometimes people mistake the 1157 for 1156. the 1156 is a single filament bulb with the positive terminal in the middle while the 1157 is a double filament with two positive filaments (one for turn/hazard, one for tail/park). if this your case, the turn/hazard is crosswired with the tail/park light at the two terminals of the light socket. your car is not completely idiot proof nor stupid proof. somebody might have made this seemingly innocent mistake
    Aug 2010
    no its not the bulbs. i replaced the tail light assembly with oem. i think the wiring is not match with the original. i need electrician to trouble shoot.
    Feb 2009
    Quote Originally Posted by cokezero View Post
    magiging okay na ul
    check or replace your grounding to your lights at the four corners. with this age of a rust magnet, chances are the grounds are bad already
    ^^^ Agree.
    Grounding is the most likely culprit here.... Make sure that they're properly secured....
    16.0K:dude:
hazard light & plate light blinking together
