Results 1 to 15 of 15
    May 2009
    mga paps,
    been to my suking auto supply and told me na halos mechanical binebenta nila na oil pressure gage...meron ba talaga available na electric? planning another DIY plus i don't want to solely rely kasi on the "engine toasted" warning light.
    Feb 2009
    Quote Originally Posted by miked View Post
    mga paps,
    is your car equipped with a pressure gauge or just a low pressure warning light? both are available but you have to determine which one your car originally have or adapt it to the instrument cluster gauge or indicator light
    May 2009
    warning light only....
    Feb 2009
    the part is is called oil pressure sending unit. you can use one for any asian car. the only factor you will have to consider is whether the terminal is blade type or pin type. the threads are all npt
    Apr 2010
    yes mayron po kadalasan pong gumagamit nito ay mga 24v na isuzu track at fuzo....
    Apr 2010
    Mga gurus pasakay naman.
    Balak ko buhayin ang oil pressure gauge sa cressida. 21R engine. Ang papalitan lang ba ay yung nakaplug sa engine? Anu tawag dun? At san ikakabit ang dulo. Putol na kasi.
    Salamat
    May 2009
    the real story behind this is that i replaced the sending unit thrice in a span of 2.5 years. the first two were the CIRCUIT brand, the third one (at present) is SASAKI brand since the NILES brand got a circular terminal.
    the reason why i want to add an oil pressure gage is to monitor oil pressure "real-time" and to eliminate immediately if the sender unit is defective.
    since i don't want any possible leaks (of hot oil, ouch!) within the driver-passenger compartment, i'm searching for the electric type....been to another auto parts, sadly they have the mechanical one.
    looks like mechanical na ang bagsak ko.
    May 2009
    Quote Originally Posted by lanceloi View Post
    paps lance,
    ang problema ko nyan e 12V sasakyan ko. tingin tingin muna ako baka meron lang jan sa tabitabi..
    Jul 2003
    try to look for the brand VEGLIA Borletti oil sending sensor/gauge. I once have this installed in my 75 galant.
    Apr 2010
    paps lance,
    here the story..nag gegeneral wiring kasi ko ng jeep and xlt..pro nag wiring ako ng owner type jeep ang sending oil nya ay ung malaki at nag palagay xa ng dasgboard na pang gasoline..sinobok ko na ilagay ung oil sending unit na malaki sa rpm gauge..gumana..hahaha..pde u itry yan ..ung sending unit ung malaki un ah hindi ung maliit..my naitatabi p yta ako nun..ung sending unit sa toyota 4k engine ko nakuha...sory n double post..paki delete na lang po..
    Apr 2010
    paps lance,
    here the story..nag gegeneral wiring kasi ko ng jeep and xlt..pro nag wiring ako ng owner type jeep ang sending oil nya ay ung malaki at nag palagay xa ng dashboard na pang gasoline..sinobok ko na ilagay ung oil sending unit na malaki sa rpm gauge..gumana..hahaha..pde u itry yan ..ung sending unit ung malaki un ah hindi ung maliit..my naitatabi p yta ako nun..ung sending unit sa toyota 4k engine ko nakuha...
    May 2009
    kamahal din pala yung veglia borletti..P1.3k wala pa sending unit. pero i'm sure tatagal. any other options?
    May 2009
    still no luck...mukhang mechanical na lang. kinukumpleto ko pa t-fittings, nipples and hex adapters.
    May 2009
    ..sinobok ko na ilagay ung oil sending unit na malaki sa rpm gauge..gumana..hahaha..pde u itry yan ..ung sending unit ung malaki un ah hindi ung maliit..ung sending unit sa toyota 4k engine ko nakuha...
    wait lang dito ha. oil sending unit tapos kinabit sa rpm gage/tachometer? i doubt...pwede siguro sending unit ng 4k pero ang tanong is tama ba yung reading sa ganong set-up?
    Apr 2010
    syempre hindi..mali ung reading nya since oil pump nilagay ko sa tachometer(rpm)hindi naman kasi para sa kanya yung gauge na un..ang sakin lang boss e mapagana namin un rpm niya khit un lang ang gamitin....
Electrical Oil Pressure Gage
