Results 1 to 11 of 11
    Jul 2010
    Hi tsikoteers,
    Can you guys recommend a really good electrical shop within Las Pinas/Paranaque area? I'm planning to get the ff. things checked/done
    - alternator - seems to be having troubles charging the battery
    - rewiring - lots of dangling wires under the hood which are not connected to anything. There are also some speakers and power windows motors that I believe are intact but electrically disconnected
    THanks in advance!
    Jul 2003
    try Tonguia Auto parts and Electrical Shop along CAA Road, just outside
    Casimiro Village Phase3. Fronting MCDonalds.
    Dec 2009
    Quote Originally Posted by tip_tipid View Post
    ok po ba dito?
    Jul 2003
    Quote Originally Posted by cyclops_23 View Post
    ok po ba dito?
    I normally goes there for automotive starter and alternator problem. Home service is also available.
    Nov 2011
    Hello Tsikoteers,
    Anyone know a good auto electrical shop or mechanic here in binondo or Tondo area?
    The voltage of my battery fluctuates widely from 11+ to sometimes reaching 16V. My car is a 2000 Nissan Sentra Exalta.
    Recently, I was stalled by battery drainage but I thought this was fixed by changing a loose plug that is attached to 1 of the terminals of the battery (2SMF less that 1 year old). Tonight I am beginning to have problems again. Comments please from knowledgeable tsikoteers!
    Quote Originally Posted by kenn.garcia View Post
    Hi tsikoteers,
    THanks in advance!
    sir, dito sa Tsikot Shop Taguig, i have partner na expert sa auto electrical. he can do the job for you. please call me at 3481728 or 09053338777 .magaling ito sir, sa kaniya ko lang pinapagalaw sasakyan ko pag dating sa electrical.
    Dec 2009
    Quote Originally Posted by jedi View Post
    sir nag se-service po b yang ka partner mo?tnx...
    Jan 2008
    Hi tsikoteers,
    THanks in advance!
    kung sa las pinas try mo yung electrical shop malapit kay kingsport katabi nung motorcycle shop dun na yamaha...
    or dun sa may bandang dating philips meron din electrical shop dun hanapin mo si juni may mga katabi pang tire shop at machine shop yun..
    Update. Made my first visit to Tonguia Electrical Shop: Tonguia's Electrical Shop & General Merchandise - Home | Facebook
    So far, OK naman. They fixed my battery discharge problem. Turned out that my alternator belt was starting to wear off. The electrician just tightened the belt a little and advised me to change it soon. (I was in a hurry. I could have had them change it right then). The electrician also asked me to have my car alarm checked as the its problem could also be causing the battery to drain fast (you have to be very close to the car to enable/disable the alarm). I asked him to check it himself but he was honest enough to tell me he was not a car alarm expert. Some dishonest electrician or mechanic would have made up some other problems in my car and pretended to fix my car alarm to up sell me. Hopefully, they will continue to be honest in my next visits. I plan to have them install my new fog lamp switch and bulb next week.
    Hi tsikoteers,
    THanks in advance!
    May 2004
    Hi all,
    Saan Gas stations or Auto Mechanic shop ang gumagamit ng Timing Light for Tuning the distributor.
    My mitsu car is old carb and point type pa. since nagchange ako ng points and condenser parang nawala sa timing.
    Sa Shell Customer Cradle ba available?
    MitsuPrime kaya?
    Ty
    Quote Originally Posted by mongze View Post
    Hi all,
    MitsuPrime kaya?
    Ty
    a timing light is not really expensive.
    look for one and buy it. yung bright light model, as it's easier to use.
    you can even learn to make your own adjustments. it's not difficult.
Recommended electrical shops in Las Pinas
