Results 1 to 4 of 4
    Feb 2012
    Ano po kaya pede cause, may times ok naman liwanag ng headlight lalo kung diretso un takbo meron times lalo kapag umpisa start sa gabi medyo kumukurap nangyayari din kapag matrapik..tnx po btw 96 sentra un car
    Feb 2009
    Quote Originally Posted by Ponkan View Post
    to pinpoint the cause of your intermittent headlight, you need to check the voltage drop across both the positive terminals and the negative terminal of your headlight socket or connector. with the black lead of the voltmeter connected to the battery negative, check the available voltage at both the high and low beam terminals at both headlight connector with the headlight switch on. then, check the negative side of the headlight socket or connector. with the red lead of the voltmeter on the positive side of the battery, check the negative terminal at the socket. any voltage lower than the available battery voltage points out either a loose connection or high resistance. repair as necessary
    possible loose connection or alternator problem yan ,get it checked by a qualified auto tech.
    Feb 2012
    last week nagpalit ako dalawang belt and so far nawala un flickering, concern ko lang mga sir if mag brake minsan nababawasan kahit papano un liwanag i dont know if normal lang un or may problema talaga electrical ko, tnx sa mga feedback mga sir
Flickering Headlights
