Results 1 to 10 of 27
- Jul 2011
- 262
July 7th, 2012 10:52 AM #1Please do advise/suggest/recommend..
Meron akong KIA pregio M/T 2004 model na medyo hindi na ako satisfy sa buga ng liwanag lalo na kung medyo maulan sa gabi so ask ko lang which is better convert sa HID or palitan lang ng higher wattage?
anu anu ang dapat i-consider kapag convert sa HID or palit higher wattage?
pros and cons?
objective is dapat ok yung mabubugang liwanag lalo na sa gabi na medyo maulan at yung grabe ang ulan at sa mga lugar na napaka-dilim na walang poste ng ilaw..
sensya na sa dami ng tanung medyo bago lang ako magkaroon ng sasakyan kaya panay tanung pa
TIA
- Jun 2010
- 321
July 7th, 2012 12:13 PM #2pag mag HID ka be responsible gamit ka projector and dapat crystal ang hl mo, i suggest buy ka na lang ng osram night breakers or all weather bulb or philip xp mas maliwanag sa stock mo, or upgrade ka ng wattage pero need ka mag palit ng ceramic sucket para di masunog wirings
- Jul 2011
- 262
July 7th, 2012 12:55 PM #3uy thanks..
so if HID be responsible, anu ibig sabihin?
yung projector ba is a type of HID? anu yung dapat crystal yung HL? meron ako nakikita H4,H5 etc anu ibig sabihin nun?
if osram night breaker/all weather bulb/philip xp eh plug and play lang ba yun? 55w yung stock so dapat same wattage lang din ba?
if upgrade ng wattage kahit anung brand ba pede na? then magpapalit ng ceramic sucket..anu kaibahan nito sa existing sucket na nakakabit..
TIA
- May 2006
- 1,668
July 7th, 2012 02:00 PM #4osram night breaker/all weather bulb/philip xp are plug and play. Mas malakas buga ng ilaw kaysa stock.
Stay with that till you can afford to go Projectors + HiD. (Garyq)
Di pwede Hid w/ existing HL ng Pregio. Glare galore.
- Jul 2009
- 3,604
July 7th, 2012 03:21 PM #5The easiest path is to go with stock-wattage bulbs with high output -- Just replace stock bulbs = Osram Nightbreaker/NB Plus; Philips XtremePower/XtremeVision. Make sure the bulbs you pick are under 60W, otherwise baka masira yung wiring/socket ng bulb.
Non-projector HID (typically prices will go under P5000 or so) will only reduce your vision, because sabog yung buga ng ilaw. Eto yung nakakasilaw sa ibang motorista
Projector HID (typically costing 10k up) - best lighting option, hindi nakakasilaw sa ibang tao, usually higher quality parts pero medyo mahalLast edited by mda; July 7th, 2012 at 03:24 PM.
- Jul 2011
- 262
July 7th, 2012 05:12 PM #6uy salamats talaga ng madami sa mga inputs/comments
yun din nga worry ko kapag nag HID masyadong nakakasilaw..eh yun pala meron palang mga klase yun..
kase im thinking dahil nakakasilaw eh maliwanag masyado na which is magiging favorable sa akin kase nga gusto ko parang daylight kapag nagdradrive ako sa gabi..so mali pala..
so i-try ko muna yung plug&play.. possible ba if walang relay eh palagyan ko ng relay? may epekto ba if wala kaysa merong relay?
TIA
July 7th, 2012 05:16 PM #7
HA?! Kakasabi lang sayo na wag kang kukuha nung mumurahing HID tapos biglang plug and play yung kukunin mo.
Alam mo na ngang nakakasilaw sa iba, tutuloy mo pa rin. Nananadya ka?
- Jul 2009
- 3,604
July 7th, 2012 05:22 PM #8I think by saying plug and play, he means just new bulbs instead of HID.
Basta below 60 watts, tanggal pasok lang ng bagong bulbs.
Subok na yung Philips Xtremepower/vision + Osram Nightbreaker +
Beyond that, you need a relay and perhaps a ceramic socket.
July 7th, 2012 09:17 PM #10
kung magtataas ba ng wattage kailangan bang mag dagdag ng relay?
kasi nung dinagdagan ko ng relay lumakas ung buga pero nasira agad ung relay
Are they on track to surpass last year's sales?
Car Sales Data (2025)
