Results 1 to 10 of 13
May 16th, 2013 12:52 PM #1
Good day, I got a second hand car, problem was when I turn off the car, the connection is still alive meaning I can still on my ac, radio, radiator fan and ac fan are still on as well. pero nawawala din naman sila after 10-15 minutes which is not normal. so I had my car checked by an electrician near dito sa house namin, he told me na hindi na original ang wiring ng kotse and merong grounded which is hindi nya ma figured out if alin he kept saying baka computer box but I insisted na baka fuse, or sockets blah blah, na frustrate na siya siguro so he ended up bypassing the connections put a relay etc as well for bypassed wires. ok na ac/radiotor fan turns off when engine is off. but the connection is still alive hindi pa din namamatay. worst is nawala yung isang ilaw sa headlight (left) which is hindi naman pundido and nawala yung bright indicator sa dashboard ko./
I need sana a trustworthy electrician who could fix my problem yung pwede ibalik sa original setting ng mga wires etc or to fix the problem rather. please refer me. I live in Quezon city along del monte.thanks.
Honda Accord EXI
May 16th, 2013 02:08 PM #2
Sir, pwede mo dalhin dito sa abad santos - quiricada. Ung Barrera electrical. Ekspert sila dyan.
May 16th, 2013 03:57 PM #3
May 17th, 2013 10:18 AM #4
hindi na cguro ako makilala dun sir. matagal na kasi nung nagpagawa ako..... anyway, pa estimate mo na lang muna pwede naman un. hindi naman kalayo dito from del monte.
May 17th, 2013 01:30 PM #5
dalhin mo kay jemson. search mo thread nya dito. sa banawe lang yun. 09322222692.
May 18th, 2013 09:00 AM #6
I would go to Jemson if Q.C. area. But Barrera also does ok work for our units in Manila.
May 18th, 2013 09:11 AM #7
May 18th, 2013 09:32 AM #8
Warranty claims depend on the warranty officer.
When Jemson changes the horn, he adds new wiring (new direct power source from the battery, new ground strap, relay). The original wiring remains unaltered so the warranty should not be affected. Nabawasan na nga ang trabaho ng original wiring because all it has to do is send a signal to the new wires to sound the horn. The majority of the electrical load is all carried by the added wiring (which are thicker).
May 18th, 2013 09:13 PM #9
May 18th, 2013 09:30 PM #10
hmm..... mismo sa kanto ng abad santos - quiricada yan sir. not sure about yakal st.
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
