Results 1 to 20 of 20
    Dec 2004
    ano ang effect pag nagpalit ka ng stock alternator/battery (ride is corolla xl 1992 12valve 1.3) to a bigger alternator (sorry di ko alam ang capacity) and a larger battery (2sm)? TIA
    syempre better power supply sa sasakyan mo at better charging para sa battery mo. kung magpapalit ka ng alternator stick ka na lang sa stock size ng battery mo.
    Aug 2005
    eh kung nag change ka ng higher battery tapos di mo na change yun alternator mo ?
    Feb 2006
    ok lang naman siguro na mag change ka ng battery as long na 12 volts pa rin siya..
    Dec 2004
    hindi ba mahihirapan ang makina kung larger alternator, kasi ang the car was designed to have a smaller alternator? what is the difference between 1sm 12v and 2sm 12v?
    Oct 2005
    Quote Originally Posted by nim ra
    afaik size sir...mas malaki ang 2sm sa 1sm...yun lang ata.
    the bigger the size ng battery mas matagal yung reserve power nya (the power that it can exert if in case masira ang alternator). hindi naman mahihirapan ang makina kung magpapalit ka ng mas malaking alternator. kahit ano pa size nung alternator mo kung di naman maganda ang pagkakabit at di naka-align na maayos sa makina, mahihirapan yung makina.
    kaya ko sinabi na wag na magpalit to a bigger battery kasi ganun din naman ang voltahe nun. pero if you want more reserved power then go palit ka. ang importante nare-recharge ng alternator ng mabuti yung battery.
    An upgrade to a bigger battery (1 to 2 sm)you'll notice that your HU lights doesn't blink that much as before. You'll have longer reserve cranking power. Do this if you intend to install amps, upgrade your headlamps (100w+) and foglamps. A higher amp alternator say 100amp will charge you battery faster as against your usual 65 amp stock unit. Of course the alternator stops charging the battery when the regulator/IC tells it so.
    If you don't intend to add amps and fogs your better off with your stock battery and alternator.
    Aug 2005
    ahh.. thanx sir.
    me nag change na ako ng battery big for my rolla.. okey nman..
    Feb 2005
    I have a charade and it uses 40A alternator ata. If i upgrade my alternator to a higher Amp rating, mahihirapan ba ang makina? TIA
    Jul 2006
    Depends on the current load you have (do you have a sound system? bone stock ba siya? etc). Do you experience flickering lights? Check all other electricals first baka ground lang or loose connection.
    The battery is just there to start the car. Once that happens the alternator generates the electricity necessary to run it (spark plugs, ECU, onboard electronics, etc).
    Feb 2005
    I'm planning to have an audio upgrade eh.
    seps, and sub lang naman ang i-drive.
    lahat ng electricals stock. baka lang kasi kapusin.
    Jul 2006
    Then upgrade the alternator and the battery to a deep cycle type. Wiring should also be upgraded so that the extra charging won't be impeded by the thin, stock wires.
change alternator
