I bought a set of Bosch EC9C fanfare horns and I want to DIY the upgrade on my Honda City.
Do I have to buy a relay? What are the steps needed?![]()
ghosthunter,
hello! Thank you! Stupid question: The EC9C has 2 horns, you connect it in parallel right? then the 2 horns will be grounded to the body of the car?
thanks again!
Tried without a relay and the results weren't spectacular. Had a relay installed. Also relocated the horn to the driver's side where it can be positioned higher and better protected from floods. The power comes directly from the positive terminal of the battery. Added wire hidden using OEM-style wiring covers.
Yes, ground is direct to body.
Don't the Bosch horns already come with a relay in the box?
I've had my horn swapped twice (first to a Stebel TM80 Magnum, next to a Bosch Windtone, both twin-tone horn sets) and they've always had their own relays thrown in.
You'll probably need to remove the bumper. That's where the stock horn resides on GD Cities and Jazzes. The Bosch horns I got have a nice high-mount bracket to protect them from deep floodwater that could easily kill them - that's what happened to my beloved Stebels. I basically had the horns relocated to the engine bay, on one of the brackets for the A/C lines.
The Bosch EC9C doesn't come with a relay though.
Even inside the engine bay, the sound is still ok? not muffled?
thanks!
Ok lang sa engine bay. That's what I did for the Patrol and Jimny because they will be used to ford water. No problem sa tunog.
