Results 1 to 14 of 14
    Aug 2007
    mga tsikoteers...at noon today, i tried to start my A/T car and it didnt start. i tried it 3x. i got down and went to the rear and noticed that yun 3rd brake light and brake lights ko were on. i think na discharge yun battery. i got a new battery installed...i started the car and it did; however, the brake lights still stayed on. so, i disconnected again one of the nodes of the battery--baka ma-discharge pa e, bago.
    what do you think is the matter with those brake lights, staying ON? ano dapat gawin? please advice
    CAR is honda civic vtec A/T. thanks.
    Mar 2005
    Ganyan din nangyari sa Lancer ko malas naubusan din ako ng battery dahil diyan. Pina check ko sabi shorted daw yung Brake Light switch sa may brake pedals. Mura lang yun switch around 200 pesos lang siya. After palitan ok na ulit siya.
    Meron yang switch sa ibabaw ng brake pedal kelangan mo tanggalin yung cover below the steering para makita mo, baka natanggal na yung rubber na nakakabit sa brake pedal na tumatama dun sa switch kaya lagi naka-on yung brake lights mo.
    Na-discharge lang yung battery mo hindi ka muna sana bumili ng bago.
    Mar 2005
    Quote Originally Posted by agp View Post
    Sakin pina charge ko lang sa battery shop.
    tama si agp bka yung rubber dun sa break switch nadurog na. silipin mo yung carpet/mat mo baka nandoon yung remnants. kung wala kang pamalit pwede mong gamitin yung center ng strap ng tsinelas. yung battery mo pa charge mo muna.
    Aug 2007
    Quote Originally Posted by jcdulog View Post
    sinilip ko nga sa ilalim at napansin ko na meron "ring/singsing" na supposed to be ay meron tatama sa kanya na metal....doon yata sa "ring/singsing" na yun nakalagay yun rubber...at kung lalagyan ko ng tsinelas, doon na sa ring/singsing na yun? WILL TRY TO PLACE A RUBBER MATERIAL and SEE WHAT HAPPENS...
    as to the battery, bumili na ako ng bago e...2 years na rin naman ang battery ko...hayaan ko na lang yun battery (altho wala pa sa schedule ko yun)
    salamat AGP and JCDULOG sa inyong information . . .
    mga sir...pwede po patulong din, napansin ko po kasi na hindi umiilaw yung 3rd break light namin, hindi po kasi ako maalam sa sasakyan kaya patulong naman po, pundi lang po kaya yung bulb? san po ba ako makakakuha ng bulb para dun? ang sasakyan po namin ay 2004 altis.
    salamat po.
    Quote Originally Posted by liteboxxx View Post
    salamat po.
    Most likely pundido lang ang bulb. Kahit saang casa ng Toyota sa spare parts division meron sila nyan.
    magkano po kaya yung bulb sir? any idea?
    anyway salamat po sa info CivicVTi.
    Wala pa siguro P100 yung bulb...kung nasa inyo ang manual ng kotse nandun din ang directions para ma-install ang bulb sa socket nya.
    Quote Originally Posted by CivicVTi View Post
    yes sir nasa amin pa yung manual ng kotse, try ko pumunta sa malapit na toyota casa sa amin para bumili ng bulb, salamat sa info sir!
    Aug 2007
    update lang mga tsikoteers sa pangyayari...
    instead of the "tsinelas", nilagyan ko ng flat-head screw yun parang "washer" na nasa dulo ng brake pedal. also, ginamitan ng hexagonal washer to keep the screw in place. hayun ...ayos na. then, re-placed the brake light fuse.
    saved me some Pesos...
    happened to me twice, ung una pina check ko sa mekaniko and un nga daw. un tinatamaan ng brake pwede sira na. 2nd time na nangyari sa akin ginawa ko ako na sumilip, tapos nag mighty bond na lang ako ng 25 cents. ayos na ayos. sakto. hehehe. wala pang piso nagastos ko since ung mighty bond napulot ko lang sa bahay namin. hehehe
    Quote Originally Posted by flakez View Post
    ayos ah, bentsinkong duling lang ang solusyon ah hehehe
3rd brake light and brake light naka ON
