Results 1 to 2 of 2
    I was wondering ... Can I use the capacitors used for audio setups in the same way one would use a Pivot Raizin Voltage Stabilizer?
    They look like they are connect in the same way, Cap + to Battery + (to Amp +) and Cap - to ground.
    While the Raizin is connect + to + and - to - terminals between the unit and the battery.
    If I take one of the Capacitors used in audio setups and wire it the same way as a Raizin, would the Capacitor have the same effect as the more expensive Raizin? Or would I end up burning my car down?
    what audio capacitor's rating you are planning to use?
    all electrolytic capacitors act the same way... mylar and other small capacitors too although they are used for small power circuitry...
Capacitors and Volt Stabilizers
