Results 1 to 10 of 12
SiRaNeko
- Jan 2003
- 973
February 26th, 2005 10:08 PM #2
para mo na din tinanong bakit nasisira ang computer, tv, stereo, light bulb, electric fan, cell phone, remote control....
sorry kulit ko ehehehe!Last edited by yebo; February 26th, 2005 at 10:15 PM.
February 26th, 2005 10:15 PM #3
as far as i know loose connection from the battery terminal is one of the reason kung bakit nasisira ang ic specially if using a quick release battery terminal.
February 26th, 2005 10:41 PM #4
does overcurrent(installing bigger batteries,prolonged running on dual batteries in parallel), over voltage(dual batteries on serial), and incorrect terminal could contribute sa pagsira ng alternator IC?
February 26th, 2005 11:24 PM #5
Sakin nasira dahil maluwag pala ang belt. The belt also drives the alternator cooling blades. Kaya ayun, sunog ang IC.
SiRaNeko
- Jan 2003
- 973
February 27th, 2005 01:17 PM #8Originally Posted by ILuvDetailing
sabi sira nga daw IC.
pumapalo ng 15+ pag idle.
kung ic palitan mga 1.3 k daw.
kung surplus na alternator 2k daw.
so nag palit na lang ako ng alternator. hopefully tumagal naman itong surplus.
February 28th, 2005 12:19 AM #9
Sa Kia din yung nasira sa akin. Palit lang ng IC dapat. Kaso pati rotor at stator nasira na pala.
February 28th, 2005 12:47 AM #10
Loose/corroded wiring and direct spraying during engine wash could also damage it.
probably safe to buy next yr. two yrs enough time to iron out the kinks. these cars are quite...
VinFast VF 3
