Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Mga boss ano kaya problem ng p/w na minsan kahit anong pindot dh hindi baba of taas check ko na fuse ok naman? San ba mafaling gumawa nu ganun thnx.
    Sent from my iPhone using Tsikot Car Forums
    May times na bumababa o tumataas?
    Quote Originally Posted by [archie] View Post
    Yes boss minsan gumagana minsan wala.
    Stuck up lang or kalawang yung mga joint. Sa evangelista Marami gumagawa, yung after ng tulay. Wag lang yung mga kanto boys.
    Jul 2010
    Pudpod na ung carbon brush sa loob nung motor or madumi na ung contacts nung sa loob nung motor
    Oct 2011
    Quote Originally Posted by red_bogils View Post
    pa check mo sa electrician sir kayang kaya nila gawin yan.
    Good day sir. May recomended auto electrician po ba kayo sa south area preferably paranaque? Having the same problem right now as stated by the original poster. Thanks all.
    Posted via Tsikot Mobile App
    Sep 2009
    Try mo pare sa Evangelista. Hanapin mo Faisan Auto Supply. Kung galing ka EDSA, kanan ka sa Mc Do. Mga 10 meters yung shop nila after nung tulay nasa bandang kanan. Hanapin mo si Jun. Dun ako nagpagawa ng Power Window at Door Lock assembly. Sabihin mo taga tsikot nag refer sayo.
    Sent from my iPad using Tsikot Forums
    Quote Originally Posted by wezz_zzew View Post
    Salamat sir. I will try this one out.
    Apr 2014
    Sa mga nkatry na magpagawa ng ganitong problem? Mga magkano po kaya mgagastos? Thanks
    Aug 2010
    Mga sir do you know a good shop for ford parts? Where can I buy power window mechanism assembly for 2010 ranger?
    Jan 2017
    Quote Originally Posted by carllomibao View Post
    Me too mga bro. I want to ask your help in finding power window assembly for 1st gen kia sportage. thanks a lot...
    Jan 2011
    Mga sir same problem din ako ung passenger window ko ayaw ng bumaba dati gumagana siya ngayon ayaw na gumana.. Saan ba makikita fuse ng window each window ba mah fuse.?? Honda city exi 97 ride ko front window lng po ang power window
    *johnlward18
    Under ng dashboard mo bro near your steering colum, above your clucth pedal, makita mo fusebox nyan. One fuse lang yan. May makita ka naman markings na nakasulat sa fusebox panel nya kung alin fuse ang para sa power windows.
    Sent from my Starmobile UP+ using Tapatalk
    May 2012
    Sakin ayaw bumaba ng passenger side window. Pag press mo yung button ramdam mo na may power pero ayaw bumaba. Ano kaya problem?
    Feb 2009
    Quote Originally Posted by hachooro View Post
    If you could hear the motor running with the switch on up or down and the window glass don't respond the regulator or cable maybe broken or dislodged
    Mar 2004
    It's stuck for long time of not being used. Pull it down while pressing power window switch.
    Paano kung problema na ang p/w motor nya. May replacement kaya nabibili, kung nais palitan?
    Feb 2009
    Quote Originally Posted by rodetor View Post
    Hehehe they were designed to break in give or take five years of normal use. Otherwise car manufacturers don't make money. After sales support make multiple times than that of new car sales. Of course the parts should be available
    and all this time, i thought they broke down because they were manufactured cheap.. that if they were manufactured to last very long, they would be "too expensive"...?
    but why is mine still ok? it's almost 10 years now... and i am not the only one...
Power window problem.
