Results 21 to 30 of 34
September 8th, 2015 09:12 AM #22
Hi Guys thanks for all the input, I finally got a replacement battery, my previous and now dead battery was called "Elektron NS-40" you guys have any idea about this brand? I replaced with a similar battery but the brand name was BK battery so just need your inputs if the new battery I got was worth it? cost me 2600 only
And is it true that a sure fire way of determining weather its an alternator or battery problem is after turning on the engine, disconnect the battery, if it continues to run then it was a battery issue, however if after disconnection and the engine dies right away then its an alternator problem? any truth to this?
- Nov 2009
- 3,509
September 8th, 2015 10:19 AM #23This is mostly true with old school diesels. Some ecu of modern fuel injected(diesel or gas) requires regulation thru the battery hence would cut-off fuel once bat gets disconnected and rpm/current is not enough to sustain the solenoids of the pumps, injectors,accessories, etc.
Battery brands? If you pay peanuts, you get monkeys[emoji16] you get what you paid for.
September 8th, 2015 11:30 AM #24
actually, mayayari din ang alternator diodes ng mga old school diesel kung ginawa yang "troubleshooting" na iyan......marami pa rin ang gumagawa ng ganyang tipo ng electrical troubleshooting.
wala kasi pupuntahan yung current na napoproduce ng alternator (kung dinisconnect ang isang battery terminal with engine running) kundi dun sa kanya (alternator) mismo.
regarding battery brands, magbasa ka na lang sa isang dedicated thread na nandito sa electrical forum.
- Sep 2013
- 268
September 8th, 2015 12:20 PM #25
September 8th, 2015 12:29 PM #26
- 54,301
September 8th, 2015 01:01 PM #28- - - - - - - - - - - - - - - - - - - - - -
from a layman's point of view...
the battery plate chemicals turn brittle when in the discharged state, and can more easily break off and fall. the more they fall off, the less the battery's ability to hold charge.
in charged state, these same chemicals are not as brittle and do not fall off.
hence the importance of keeping your battery in charged state.
November 25th, 2015 08:20 AM #29
My MS battery is 3.5 years old.last week hindi na mag start.it need charging or replace a new one?any idea po thank you...
November 25th, 2015 09:16 AM #30
Bring your car to motolite. They have a tester that can determine if its the battery or alternator.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
