Results 1 to 2 of 2
- Jan 2009
- 16
November 28th, 2009 04:37 PM #1help!
nalubog ang kotse (lancer gls 01 A/T). got revived naman, but so far, walang panel lights: odo, tacho, fuel, temp, gear lights (sa dash, yung PRND tsaka 4 3 2 1), km/trip panel, AC/thermostat, gear light indicator (yung sa may kambyo). so hirap magdrive sa gabi.
when you turn ignition, on ang clock at yung gear light sa dash (usually asa P). when you turn the parklights (or headlights) on, namamatay yung gear light sa dash, at humihina yung ilaw sa clock. yung iba wala talagang ilaw. btw ok yung ilaw ng check engine, high beam, low fuel etc (mga warning lights).
sources say baka dimmer switch, yung iba fuse or relay. mukhang ok naman mga fuses, haven't checked relay or dimmer yet...
thanks!
November 28th, 2009 04:45 PM #2
Pa check mo na lang sa auto eletrical shop para matignan tuloy iyong electrical wiring ng sasakyan mo kadalasan pag nabasa iyong wire at fuse box at relay kinakapitan kasi ng kalawang at umido ang mga contact nito.
VinFast VF 3
