Results 1 to 11 of 11
    Jul 2003
    Bakit namamatay yung Radio if I Sw ON the Wiper. and also minsan yung signal light, parang maagawan yung power ng Radio, pinacheck ko yung alternator ok naman daw yung Charging. Battery ok pa naman 1 click pa sa umaga, kaya lang 2 yrs. na ito. any comments.
    Please post all vehicle problems, maintenance, troubleshooting, etc. in the WorkShop forum.
    Moving to the Workshop Forum.
    Dec 2003
    have ur electrical system checked, grounds, wirings etc.
    must be how your radio was hooked up, baka tinap yung power or ground sa combination switch (wiper/signal) switch.
    Aug 2005
    have a somewhat similar problem with my mitsubishi adventure. sometimes, it's as if there isn't enough battery power: engine won't start, all lights including indicator lamps are weak, and power locks don't work. BUT, after a while (i try to flick switches here and there, with emphasis on the headlight switch), everything returns to normal. when it returns to normal, usually the cd player resets and any cd inside is ejected. and the engine starts without any problem. what compounds my problem is that it's very hard to reproduce.
    i don't think it's the battery cause it's new. could it be poor grounding? where? perhaps in the main supply from the battery? or a short somewhere?
    i'd like to have it checked by a good electrical repair shop. i couldn't find the wizards contact info anywhere here. any suggestions?
    May 2005
    Quote Originally Posted by tikoy
    sir TIkoy...subukan nyo pa- install ng grouding kit muna ..around 900 pesos yata iyon or pwede mo din DIY kung makakabili ka ng mga specific materials
    sir Tikoy..click this link may direction po diyan ng addy ng wizzards.
    http://tsikot.yehey.com/forums/showt...hlight=wizzard
    BTW welcome po sa tsikot.com
    Aug 2005
    thank you very much for the tip and the welcome, sir BoEinG_747.
    i posted too early, found the wizards contact info 5 minutes after posting
    i will try you suggestion. DIY solutions are definitely welcome!
    Jun 2015
    guys san b ako mkkbili ng alternator with good quality? mahal kc msyado s casa. for transport use kc. tnx guys!
    Jun 2015
    guys san b ako mkkbili ng alternator with good quality for my mitsubishi adventure? mahal kc msyado s casa. for transport use kc. tnx guys!
    Quote Originally Posted by acenie View Post
    hindi sa battery or sa alternator yan.... its the wiring..... there is a ground somewhere.
Battery or Alternator
