are the small air compressor being sold in shops any good? the one where you plug into cigarette lighter. what brand would anyone suggest? i saw one, its about the size of 3 soda cans and built in guage for tire pressure.
ok lang naman yang mga maliliit na compressor na yan my brother has one on his car. pero, I personally prefer yung mga mechanical footpumps. exercise na, hindi pa dadadag sa electrical load ng auto ko.
Ours lasted close to 20 years. This is the "Laser" brand made in the US.
Lumuluwag lang yung electrical connections sa loob dahil sa vibration ng compressor. Pero pag hinigpitan mo ulit yun ayus sya ulit. Took 18 years before anything like that happened on ours.
One tip: Hwag mo tipirin. The cheap PhP500 compressors are usually crap.
tire inflator? yes for emergency purposes. mine is from US - dunno the brand name basta may red na star malakas siya! kahit dapa na gulong kaya hanginan but mas di hirap kung jacked up.
Ok yang tire inflator for emergency purposes. Kaso yung mga local brands mabilis masira. Better get the US branded ones, tumatagal kumpara sa mga local/china made.
Pag local pumps, dapat jack up muna yung tire para hindi hirap magkarga ng hangin.
madaling masira kung mag overheat kasi may plastic component sa loob (rotor yata) na madaling ma-deform. Go for the double barrel bicycle foot pump & have a reliable tire pressure gauge...
I have one na lagi kong dala for emergency I bought it for 400 pesos. More than two years na sakin ok pa naman and I use it everytime bumababa ang psi ko. Siguro once a month. Swertehan lang sa pagbili. What I did was naglagay ako ng on/off switch malapit dun sa pump para hindi hugot ng hugot everytime papatayin yung pump. Saves me time and energy sa pagbalik-balik sa loob ng oto
I have a couple of these air compressors and both of them still work okay after more than 5 years. Very handy in case of an emergency when you needed to inflate your tyre and ran a few kilometers to have a tyre change....
mayron ako at napakinabangan ko na sa car ko ng ma flat minsan.
na inflate din naman up to 30psi sa indicator ng pump na yun pero ng makarating ako sa vulcanizing shop at pakargahan ng tama, 21psi lang pala. wala namang butas gulong ko mali lang gauge ng pump. ok lang. bottom line is, napakinabangan ko naman kahit papaano.
bago ko binili yun (SM Southmall) nag test muna at pinaabot ko ng 60psi yan bago ko binili(binaluktot yung dulo ng hose at pinaandar) if my memory serves me right naka pangatlong palit ng unit yata kami sa pag tetest bago naparating namin sa 60psi kasi di tumataas ang reading nasa first grad lang which is 20psi (daw!!) yung first two units. hehehe.
250psi pa gauge nun "too good to be true." kasi sa hitsura at materyales lang mukhang di aabot sa 100psi at sasabog na eh.
i used to have one, madaling masira. I bring a machanical pump along, over ten years (may be even more, sa bike ko pa yata to nung single pa ako) it still works without fail.
mas reliable ang double barrel foot pump kesa sa yung mga cigarette powered air pump. yung liteace namin napahanginan ko without jacking up the tires. :D
