Results 1 to 4 of 4
    Feb 2012
    Hello guys, need help,
    Toyota corolla Big Bidy 97 XL ang tiskot ko.
    Bagong linis ang starter at Malakas ang battery.
    Pag start ko walang wala maririnig kahit tick.
    Pag disconnect ko at reconnect ko ang ground sa battery, mag start na tsikot ko, na parang walang ka probleproblema.
    Pag nag park ulit ng matagal, ayan nanaman di nanaman mag sstart unless disconnect / reconnect ang ground sa battery.
    Wala computer box ang tsikot ko, at wala rin neutral sensor.
    Help! Maraming Salamat!
    Feb 2009
    Quote Originally Posted by escudoparanoia View Post
    revisit your starter again, it might be loose on the engine block or the terminal 30 cable is loose on the solenoid bolt. if it did not have this symptom prior to the removal of the starter, repeat the process of removing and reinstalling the starter. if the brushes are worn out, this will cause an intermittent crank/ no crank problem.
    Jun 2011
    sir usually old model cars has grounding problems... lagyan nyo po ng extra ground yung starter nyo papunta sa battery... use battery cable sir...
    Aug 2008
    i agree po its a grounding problem ,pag tinatanggal mo yung cable to ground dumidikit ulit sya ng maayos then pag umandar ka na at naalog na due to vibration nag loose na sya ulit
Ayaw mag start unless disconnect reconnect ang battery
