Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    2 yng battery ng lnd cru ko.... kelangan ba sabay 2 pag papalitan ko?
    dalawa ba battery ng land cru? para pa lang space gear ano
    dapat sabay para pareho new, kung hindi baka mahirapan yung isa (not sure please correct me if im wrong)
    just to be sure palitan mo na sabay!
    lc80,
    click on the link to ai.ORG sa sig ko, may poster dun na drexx ang name, naka-LC din siya, pero sa US siya based. you could ask him, just to be sure, and I'm sure he could help you a lot. nag-offer siya dati ng parang catalogue yata ng mga LC parts, with part numbers pa yata, not sure lang, dig through the old topics, I'm sure you'll find it...
    hard core offroader din yata yan...
    good luck!
    lc80::: Pa-check mo muna isa isa yung mga butas ng batteries mo. Pag may patay na butas tsaka mo palitan pero kung buo naman yung isa ok lang. Pwede ka pa mag start nyan kahit 1 battery lang gamit mo. The other one is for your vehicles accessories lang naman. As long as umaandar alternator mo safe ka, at hindi ka ititirik nyan. Pwede mo namang jumper yung isa incase pumalya sa gitna ng daan.
    crawdaddy,
    JDM yung LC80 ni lc80 kaya naka-dual battery setup. Yung kay drexx USDM, single battery lang.
    lc80,
    Palitan mo na ng sabay, tapos akin na lang ang pinaglumaan.
    JUST REPLACE THE BATTERY THAT NEEDS TO BE REPLACED. KEEP THE BETTER ONE AND USE IT FOR THE AUX / ACCESSORY SIDE. USE THE NEW BATTERY FOR STARTING.
    CAUTION : IN ALL PROBABILITY YOUR VEHICLE HAS AN EMS (ELECTRONIC MANAGEMENT SYSTEM) DISCONNECTING/REMOVING BATTERIES MAY RESET OR DAMAGE IT. THERE MAY BE A SEQUENCE OR ORDER IN DISCONNECTING THE BATTERIES, CHECK YOUR MANUAL.
    teka dalawa yung battery e di 24 volts yan? parang elf namin? hehehe :Pteka dalawa yung battery e di 24 volts yan? parang elf namin? hehehe :P
    mdpo,
    Yup, 24V ang mga big SUV's at commercial vehicles sa Japan.
    hmmmm..... i always thought naka parallel yun :D Yung jdm pajeros dual batt din.
    Parallel ba? All the while kala ko hiwalay sila ng work load. One for the engine and starter and the other for its accessories. :shock:
    i think parallel sila. I dont see any advantage in powering two circuits independently. besides, parang mahirap mag charge ng 2nd batt kung hindi connected sa alternator. whereas having two batts in parallel would provide you with longer battery capacity, source redundancy etc. Kung naka series naman(24V), most of the electrical stuff wont be compatible. Kahit simpleng headlight bulb.
    In any case Jan, Ok lang isa ang palitan. but of course para mas ma-feel mo yung increased efficiency ng batteries, change both :D
    Quote Originally Posted by OTEP
    crawdaddy,
    lc80,
    LC80::: yon isa sa akin, ha :lol:
    Ngeee.. ano na yan.. kakahuyin nyo na ba yung LC80?
    Kung ganun akin na lang yung front diff locks and sound set-up mo Jan!!! :mrgreen:
    Battery lang po ang pinag-uusapan dito :mrgreen:
    Ay ganun po ba?
    Sorry, kala ko lahat ng parts connected or nakakadagdag drain sa battery kasama. :mrgreen:
    yung sa jeep ko 24volts electrical system.
    isa lang ang pinalitan ko. yung sira lang.
    so far, more than a year na no problem naman.
    24V ang mga JDM na LC80. That's what it says on the voltmeter. Yung sa Dubai LC namin 12V system lang.
    di na lang ata ako magpapalit... tatawagan ko na lang kayo pa tumirik ako sa daan :mrgreen:
    cguro try ko isa lang muna palitan...low budget eh...
    Quote Originally Posted by Freeman
    la akong manual eh...hehe
    Quote Originally Posted by lc80
    im sure kong obet knows the answer.
    if you need his number text me.
    kakilala ka naman niya.
kelangan ba 2 battery sabay palitan?
