The simple answer is YES.
There is a built in relay? Where? In the technician's imagination?
Using the stock wiring is the lazy method. Perfect if you delight in blowing the horn fuse of your stock wiring system. Even dumber are installers who just slap on a higher rated fuse which essentially defeats the purpose of the fuse (which is to act as the weakest link).
The correct way is to lay down a new power wire (from the battery or fuse block), new ground wire, and new wires leading to the horns. The stock horn wire will now be just used as a 'trigger' wire to trip the relay and complete the circuit to fire the horn.
This way, it will be impossible to overload the stock wiring.
