Results 1 to 8 of 8
- Feb 2013
- 32
January 10th, 2017 06:20 PM #1Hello everyone! I have a problem with my high beam lights. Hindi gumagana yung high beam. When I push the lever completely, nakapatay lahat ng lights. Kahit yung pagflash lang ng high beam (pulling the lever towards you), hindi rin gumagana. The bulbs are working naman on low beam. What could be the problem?
Thanks in advance!
January 10th, 2017 07:55 PM #2
Check the bulb first. Baka pundi na talaga yun high beams
- Nov 2016
- 13
- May 2011
- 227
January 11th, 2017 06:10 AM #4Buy cheap bulb to test baka pundi na kasi. Pag ayaw pa din try mo un advise ng nauna sakin
- Feb 2013
- 32
January 12th, 2017 12:14 AM #5
- Feb 2013
- 32
January 12th, 2017 12:16 AM #6
January 12th, 2017 03:09 PM #7
kung kaya, silipin nyo po kung putol na o hindi yung filament ng bulb withouth getting the bulb out of the lamp
kung maidentify ninyo kung alin yung relay ng headlight e pwede nyo muna iswap sa isang relay na ginagamit din sa sasakyan ninyo provided parehas ang pin lay outs ng relay.
beyond this e connection problem or the switch...
- Feb 2013
- 32
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
