Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Mga sir, patulong lang. Meron ako second hand na owner type jeep. Gusto ko lang sa sana malaman ang mga ito:
    • How to know/check alternator's and battery's rating/capacity?
    • What tag or label to look for?
    • In case no more label or tag, ano ang iba pang paraan para macheck?
    Gusto ko kasi malaman ang safe load/capacity alternator-battery ko na hindi magkakaproblema.
    At ano pa ang pwede kong idagdag na mga accessories.(e.g. lights, carstereo, etc.)
    Mahirap na kasi kapag hindi aware tapos magkaproblema sa kalsada.
    Cguro tama naman yung concept na ito na alternator ang mas mataas dapat ang rating which must be enough to charge battery at operating condition without getting drained:
    Alternator rating > Battery rating > Load
    maganda na rin malaman ito at maapply kapag may kotse na ako.
    maraming salamat.
    Feb 2009
    Quote Originally Posted by naruto85 View Post
    maraming salamat.
    most of starting/charging systems setup are within +/- 15 % of the starting system. for example toyota camry 2.4 liter engine uses 1.4 kw starter motor (1400w/12 v= 117 amps, the alternator is 100amps. the battery for the setup is 100amps X 6= 600 cold cranking amps battery. to determine your total current load, run all electrical loads like headlight on high beam, tail lights, blower motor, wipers and rear window defogger while measuring the current using an inductive pickup type ammeter. the loads should not equal to nor exceed the current demand of the starter
    Bossing, hindi ko makita/malaman ang rating ng alternator ko eh. Paano ko pa kaya yun malalaman?
    Saan makikita?
    Feb 2009
    Saan makikita?
    you can google nippon denso alternators and use your alternator part number to find out. or you can use a VAT ( volts/amps tester) and observe the charging rate under load. the instrument will tell you the current output.
    Ano ba makina ng owner type jeep mo .
    Quote Originally Posted by speed unlimited View Post
    4K daw eh.. wala pa kasi ako alam sa mga makina...
    eto lang ang nakita ko sa makina..
    toyota 4K 1005381
    ano mga bossing ibig sabihin nyan?
    tapos sa alternator eh parang ganito:
    ..27020 11021 (nippondenso)
    hindi na kasi makita ng maayos eh masyado luma..
    (currently searching sa google ng nippon denso, bigo pa lang)
    kung sakali may idea kayo...
    sana may makatulong..
    salamat....
    Sep 2008
    kung 4k at orig pa ang alternator. 15 amps yan. nga new cars nagyon na sa 60 amps na ang capacity. but dont worry. madami piyesa. kahit 60 amps ang ikabit mo pwd yan. kahit anong battery size pwd yab basta 12v. the bigger battery size the higher ampere rating.
    Feb 2009
    toyota 4K 1005381
    salamat....
    your engine came out of a toyota starlet around the early eighties. you might want to ask around banawe, they will have this alternator and it will show the current capacity on the sticker
    sa 4k engines alt rating nila 45A int reg or ext reg pareho lang
    batt rating 500 A
    CCA 400A
    sa battery pwede na ang honda civic 90's model
    ok din ang batt para sa 90s corollas
Alternator and battery rating
