Results 1 to 4 of 4
    Had my alternator hose replaced 2 weeks ago because of oil leak. Since then 2 times nako nagpalit dahil yung hose napuputol. The problem is natatapon yung langis sayang. Kelangan ba orig yun kasi replacement lang pinakabit ko, kala ko dati factory defect lang yung replacement part na napakabit ko kaya replacement uli binili ko.
    Just have it replace by a shop that specialized in industrial hoses for heavy equipment. mura lang yan. had my alternator hose of my patrol replaced last Thurs. Cost me only 150 php (yes, 150) for the hose (German made) and the fittings. Around 4-5 inches ata ang length niya.
    if you're interested, there is a store (formerly ABC hoses) located along rizal ave and 1st st. in caloocan that does crimping and has stock of hydraulic hoses for your needs.
    Nagpagawa na din ako ng hose diyan sa ABC. Kasama ko si afrasay. Bridgestone naman ata yung ginamit na hose. Steel reinforced. Pamalit sa powersteering hose ng Sentra na pumutok.
    Tapos pinakabit ko sa pinsan ni afrasay who is a mechanic that lives nearby.
L300 alternator hose problem
