nakabili nako ng charade 1995. 4 cylinder din pala 'to? at 1.3? hindi ba 'to malakas sa gas?in very good condition naman at wala na talaga pagawain. what can you guys say about charade 1995?
tipid din ba 'to sa gas?
Kung good condition makina alagaan mo na lang sa engine maintanance para tumagal ang makina . Matipid sa gas dahil magaang ang kaha at maganda sa city driving madaling mag park .
With the pending implementation of E10 gasoline in all gas pumps by 2010, you will have to adapt the engine to run on ethanol blended gasoline. If not, the carb jets with erode quickly.
Aside from the jets, you will have to check the fuel tank and fuel lines as well. You might find the fuel tank full of rust and fuel lines leaking with pin sized holes.
To read more about ethanol blended gasoline or E10 gasoline, click the link below.
http://tsikot.yehey.com/forums/showthread.php?t=59222
For the meantime, you will have to avoid gasolines with E10 and only use brands without E10 yet like Petron XCS.
