Results 1 to 16 of 16
    Aug 2016
    Magandang hapon mga chief!
    Tanong lang sana ako saan okay magpagawa ng car door lock?
    Bale all 4 doors are functioning well, then yung back door di na sumusunod sa unlock. So palagi lang siya nakalock.
    Any tips kung saan okay magpagawa?
    Maraming salamat!
    Sep 2012
    Quote Originally Posted by Frijolito View Post
    Maraming salamat!
    Do you have an alarm / keyless entry installed?
    If yes, lumuwag lang sa actuator yan and pwede mo ipagawa sa nagkakabit ng alarm
    Sent from my ASUS ZenFone 4 using Tapatalk
    Aug 2016
    Quote Originally Posted by jodski View Post
    Yes boss, keyless entry siya. Kaso sa casa pa kasi ito sa pagkakaalam ko.
    Pero syempre pag sa casa kasi, papalitan nila buong assembly which will be cost expensive.
    Any alternatives po kaya?
    Sep 2012
    People from Banawe can fix that...
    Saan ba area mo malapit?
    Maybe other tsikoteers can recommend a good shop
    Aug 2016
    I mean like recommended shops po like kunware saan specific sa Banawe or any other place (Boni Area is preferred).
    Thanks sir.
    Aug 2016
    Boni and Pioneer area sir.
    Oks salamat sir. Wait na lang ako for recommendations.
    Aug 2016
    Any recommendations po mga chief? It will be much appreciated. Thanks.
    Jan 2009
    The latch is an assembly. It includes all mechanical parts and the motor. When my then Civic FD had problems with the passenger side door (locking/unlocking is intermittent), I ordered a used door latch assembly from eBay (removed from a totaled car). Cost me less than 3k (landed). At the dealer, it will cost me anywhere between 7-9k.
    Here's the link for the Jazz/Fit. Check if it looks the same as yours.
    #67 HONDA FIT SPORT 9-11 TRUNK LIFTGATE HATCH LATCH LOCK 7481-TK6-A1 | eBay
    Nov 2007
    Search mo Rey's electrical
    when my (non-honda) door lock/unlock died, i took it to banawe. the guy got the assembly out of the door, and replaced the small electric motor, all for less than 2 K. all done in less than an hour.
    buying a replacement part without knowing first what is wrong with yours, might be an expensive proposition.
    Jan 2009
    I didn't just decide to replace it blindly. I'm 45 and all my life has been dedicated to breaking and rebuilding stuff.
    Of course I did due diligence and confirmed that the part was actually defective before ordering a replacement. And in my case, it wasn't the electric motor, rather, a small gear that has cracked and started slipping from its shaft is what's causing me a lot of greef.
    I figured that I just get it over with and looked for the whole assembly. I eventually found one from a wrecked 2011 Civic (USDM) posted on eBay for $48. Part numbers were almost identical but more importantly, they looked exactly the same.
    I replaced the whole assembly myself.
    Spending just a little under 2.5k* for the whole latch assembly (including S&H), it's a bargain. I got to learn about the innards of the car door pa.
    *Note: My earlier estimate was based on the current Forex. The Forex rate at the time I bought it (March, 2014) was just around P45 to the US Dollar.
    well, you did omit this little tidbit of information, from your original post...
    but i am happy, that some folks still tinker with their cars, the old-fashioned way.
    errr... grief po. grief.
    Jan 2009
    Yeah, well, it was right about midnight and my spelling skills went to bed ahead of me.
    All those Peanuts comic books I've read as a child going to waste, I've put shame upon Charlie Brown.... Good grief!
    heh heh heh.
    ok lang yan. na-i-intindihan naman, e.
    now, if only we can do the same to "breaks"...
    Mar 2016
    Maraming salamat!
    Boss, buksan mo may natanggal lang po yan sa loob, ganyan din sa akin dati yong door ko sa right side sa hulihan ayaw din sumabay kapag lock at unlock meron lang akong kinabit kc natanggal diko lang alam ano tawag don naka-kalawit sya yun lang napansin ko na nakatanggal sya yung tumutulak ng unlock at lock. buksan mo tapos pindot pindutin mo remote makikita yun gumagalaw... sana makatulong ako...
    Sep 2018
    Same problem po tau. Sa batangas po kaya merun kaya magaling gumawa pero mura
Back Door Lock Malfunction - Honda Jazz 2009
