Results 1 to 7 of 7
May 20th, 2012 03:09 AM #1
guys ano problem nung central lock ng pickup ko.. bagong install lang ito nung january
wala pang 1year pero nag loloko na tsk..
anyway ito yung problem, minsan both rear doors ayaw bumukas pero gumagana naman actuators hindi lang talaga nabubuksan ng todo.. tumitigil sa kalahati yung lock kelangan ko patuloy itaas yung lock para lang mabuksan yung doors.
nangyayari madalas pag patay yung kotse :| may instance na ipapagawa ko sana pero nung pag on ko ng kotse gumana naman yung locks.. baka mairita lang yung gagawa kasi sasabihin na gumagana naman.
may warranty pa naman yung lock, ipa backjob ko nalang kaya?
May 20th, 2012 03:47 AM #2
Usually, its the linkages that your installer bent that are at fault if the motors are ok. Most shops accept that as a backjob and fix the linkage or reposition the actuator.
May 20th, 2012 10:23 AM #3
Agree with Sir Otep, there may be an obstruction with the rod when the actuator is moving. Easy to repair but the dismantling and re-installation of the dashboard may take longer time than the repair itself.
- Oct 2009
- 2,271
May 21st, 2012 08:48 PM #4pa adjust mo lang ung naka kabit sa acuator saka dun sa hatakan ng lock sa loob malamang umi slide na yan..or na adjust na sa katagalan kun di man lumuwag na siya kaya nawala na sa dating timing..
same problem with my ride..
May 21st, 2012 10:22 PM #5
salamat mga sir!
pinabackjob ko na ito last week kaso isang pintuan lang ginawa nung mekaniko yung kabila di niya ginawa kasi okay naman daw "nung time na yun" ang dami niya pang sinabi na mas maganda daw kung may switch yung central lock para hindi pwersado yung actuators :| anyway.. yung isang pintuan na ginawa niya okay naman pero minsan talaga pag nakapatay yung kotse parehong yung pintuan sa likod ayaw bumukas..
hindi kaya sa kuryente ng auto ko?
May 21st, 2012 11:08 PM #6
Ewan ko diyan sa shop na pinuntahan mo sir. Dapat check niya lahat.
And wala kinalaman ang switch sa pwersado or whatever. Hehe.
- Jun 2007
- 1,161
May 21st, 2012 11:18 PM #7nangyari na rin sakin yan....
binaklas ko yung panel ng pinto tapos inispreyan ko ng WD40 yung mga joints ng mga may kinalaman sa pag open ng door.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
