Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Quote Originally Posted by YooShh17 View Post
    Ginwa yta ng electrician rekta sir.
    Mainit tlga n halos 1sec lng mpapaso kn ng todo
    yes, rektra can do that.
    but that also means, it can be fixed easily thru the addition of relays.
    Jun 2016
    Find another electrician. A real one this time.
    Jul 2016
    how hot? if slightly warm only, puede na. anything more than that, is bad.
    1. low capacity switch. upgrade to higher capacity or heavier duty switch.
    2. poor electrical connections. re-do the connections.
    3. defective switch.
    tekateka... naka-rekta ba yan? o, may mga relays? dapat ay may relays.
    Agree. Kung na bypass yung relay at naka direct connection yung switch sa load and power source you definitely need a larger capacity switch that can handle the amperage. Or small switch pero dapat naka relay
    Do what everybody says, padagdagan mo ng relays tsaka bili ka na din ng bagong switch kasi na-overload na yang switch mo sa stress ng init kaya better to be safe than sorry. Minsan yang kagustuhan mo makatipid ng konti pag minalas ka mas malaki pa masisira worse baka masunog pa kotse mo.
    Do what everybody says, padagdagan mo ng relays tsaka bili ka na din ng bagong switch kasi na-overload na yang switch mo sa stress ng init kaya better to be safe than sorry. Minsan yang kagustuhan mo makatipid ng konti pag minalas ka mas malaki pa masisira worse baka masunog pa kotse mo. Kung di ka pa din natakot isipin mo, what if nakasakay ka nang masunog, kung nakapark naman, what if sa gabi mangyari at pati bahay mo madamay. Konting halaga ng relay at switch kapalit bahay o buhay, ikaw na pumili.
    Jul 2016
    salamat po sa tulong ninyo ok na po !
Help... Switch ng Ilaw
