Results 1 to 10 of 11
- Sep 2013
- 153
February 16th, 2014 02:25 PM #1Hello,
I just found out this morning that any key can be use to open the lock of my car's driver's side. I tried using our house door key and it worked. Even tried another key and it also worked. I tried doing the same testing on the passenger side, fortunately, it is not the same as the driver's side. To which shop can I have this fixed? Have anyone experienced the same issue as mine?
Thanks!
February 17th, 2014 09:55 AM #2
- Sep 2013
- 153
February 17th, 2014 10:02 AM #3Where can i buy a set? Is the ignition key included in the set?
Posted via Tsikot Mobile App
- Aug 2012
- 2,767
February 17th, 2014 11:15 AM #43 locks/set ang nakikita ko sa sulit. Solex brand. i think this is for driver side + passenger side + trunk/rear door. actually, kahit yung driver side lang palitan mo eh. but if gusto mo same key yung 3 doors, change mo lahat.
sa ignition naman, keep it as is and use the old key. hindi naman bibigat ang keychain with 1 extra key.
if you want, pa-install ka na rin ng alarm with central lock system pare keyless entry na with remote.
where to buy? Ace, Concorde, Blade, etc. or punta ka Banawe area.
- Sep 2013
- 153
February 18th, 2014 09:26 AM #5Nakita ko ung solex na brand na nakita mo sa sulit kaso di kakasya sa oto ko ung pre. Maliit kasi ung susian and nakalubog ung susian ng oto. Honda civic 97 ung oto ko pre.
February 18th, 2014 09:33 AM #6
Kung makakahanap ka ng susian na similar sa oem, may mga locksmith na kaya nyang baguhin yung pins sa loob ng new locks mo to fit your old key, kahit isa lang palitan pwede..
Posted via Tsikot Mobile AppBeep Beep! School Bus! Beep Beep! School Bus!
February 18th, 2014 09:44 AM #7
- Aug 2012
- 2,767
- Sep 2013
- 153
February 19th, 2014 05:09 PM #9Salamat mga sir sa info. Try ko maghanap ng ganun. Salamat!
- Nov 2012
- 200
February 26th, 2014 06:25 PM #10punta ka ng banawe TS dami dun locksmith palinis mo lang yung susian mo malamang na-stock lang yung pin niya na nakapantay kaya kahit anong susi pwede, ganyan din sa tropa ko dati kahit nga flat screw isaksak mo iikot pa din at bubukas pinto nung binaklas namin konting taktak ng susian ayos na ulit pero after ilang weeks ganon na naman dinala niya daw sa banawe binuksan din tapos binabad ata sa penetrating oil tapos nilagyan ng konting grasa ung outer para di pasukin ng alikabok at tubig ok na mga 1 year na siguro di pa ulit nagloko
Thread was made nung 2018 pa po sir.
