Results 1 to 11 of 11
    Jun 2008
    guys, meron ba ditong naka-code 8 na siren? code 8 yung brand niya. usually sa banawe nabibili.
    any feedbacks? sabi kasi nila may tone siya nung parang katulad sa whelen.
    They're probably talking about the HF (high frequency) and horn setting typically used by the PSG (who run Whelens).
    Frankly, if you're used to sirens medyo malayo ang sound.
    We use that as a back up siren sa ambulance in case the Whelen unit fails or we need more sound to punch through traffic.
    Oct 2008
    Ano po mas maganda Code 8 or Magnum???
    Quote Originally Posted by yuyuti View Post
    sir magkano po ang code 8? same din po ba ng other china made like magnum? thanks..
    Maganda Code 8 kesa sa Magnum. Yung Code 8 May tone siya na medyo similar sa Whelen. Maganda Code. The best kung sa Local.
    May 2008
    Really? I've always though that Code 8 sounds way too different from Whelen. Lalo na yung wail. I've auditioned this taiwan-made siren at this mall and it sounds better.
    Oct 2008
    Tap lang ba Interceptor sa Battery Terminal?! Will use siren for Parade Campaigning in our province.
    Yup. Rekta lang po.
    Oct 2008
    Yup. Rekta lang po.
    OT: Mahal kasi pakabit sa mga electrcial shop, 380-450php! Sir gusto ko sana i-diy, kabit sa pick-up ni uncle, tap ko lang po ba wire ng Interceptor mismo sa Battery Terminal, then tap ko rin trompa sa battery terminal?? Need ko po ba lagyan pa ng relay?? 100watts po yung siren
    Ano po ba basic proper procedure sa pagkabit?? hindi po siya permanent, for campaign parade use only!
    Mga Php200 lang labor kina Glenn sa Kamias. Saan iyang Php450? hehehe. With relay yung kinabit sa unit eh.
    Oct 2008
    Sir, pwede ko ba i-diy lagyan ng switch yung siren? Sa horn button nalang ako pindot then pag normal busina, switch ko nalang! Dali lang ba i-electrical noon?!
Code 8 Siren?
