Results 1 to 13 of 13
    Jul 2011
    Dear Sir's, ask ko lang kung meron kayong alam na car alarm na kayang i-detect kung meron dumidikit sa car (sumisilip sa bintana or worse ginagasgasan na ung body paint).
    Ung stock alarm ko kasi pag ginawa kong sensitive kahit tambutso lang na malakas nag aalarm na (istorbo), pag mid ang setting nakadikit ka na sa car ala pa din na detect.
    Kaya po ako naghahanap kasi kahapon meron sadyang gumasgas sa right side (rear to front) ng car ko, 2 door ko gasgas.http://tsikot.com/forums/images/icons/icon9.png
    Quote Originally Posted by Manilablock View Post
    wala atang ganyang ka sensitive na alarm bro.
    baka cctv camera na katapat nyan... ;)
    Perimeter alarm, pag may lumapit w/in the perimeter covered ng car saka mag-a-alarm.
    (nabasa ko lang din sa specs ng isang car, hindi ko lang alam kung meron na sa after market.)
    Oct 2011
    Ayos yan perimeter alarm kung talagang nasa garahe or isolated ung sasakyan kung hindi aalarm ng aalarm yan.
    Jul 2011
    I was thinking nga ng DYI, another car alarm na gawin kong sensitive, instead of horn i-tap ko ung output sa relay, pag na triger ung alarm, ung rely mag close at provide power sa dashboard cam, if wala nga available sa manila ng car alarm na gusto ko.
    Ito ung naiisip kong parts list
    1. Car Alarm x1
    2. 12V Relay x1
    3. dashboard cam x3
    Parang aabot din ng 5k, kaya maghahanap muna ako ng ready made na
    it's called a security guard.. heh heh.
    but seriously, your alarm will have to be hooked to a computer with image recognition capabilities, and logic/fuzzy logic (thinking) abilities.. otherwise, it will activate when animals, large leaves, rain, even a strong wind, comes up..
    good luck just the same.
    Pwede rin hire a driver. Lagi may nakabantay.
    I want one too.
    Naasar kasi ako sa mga humihingi ng barya pag bagong linis car ko dinidikit pa mukha.
    Oct 2011
    Quote Originally Posted by MrGunn View Post
    pwede rin aso ilagay sa loob ng sasakyan.
    May 2010
    Mag lagay k na camera for ur safery. Merun nabibili para mga cars. Sa alarm wala ng gusto mangyari.
    Jul 2011
    only choice ko for now ay bumili ng bagong car alarm.
    ung output nya para sa horn ang ikakabit ko 12volt na relay
    ung relay, sha ang mag control ng supply ng power para sa dasboard cam
    pag na triger ung alarm, mag close ung switch sa loob ng relay, magkaroon ng power ung dashboard cam at start recording na.
    pag umalis na ung nag trigger ng alarm, shempre titigil na din ung car alarm, mag open ulit ung relay, mawawalan ng power ung dashboard cam
    at the end of the day or when you notice something had happened to your car, time to watch ung mga images captured by the dashboard cam.
    Hopefully bukas magawa ko ito if all goes well sa aking budget officer, hehehe
    Sep 2012
    sir, kaya kaya ito.. pero not for a camera to capture images but for an actual 12 volt or higher current running around your car? Yun pong tipong when someone touches it, maga ground or makukuryente, not to the point of paralysis of course, pero enough to deter people from playing with your car when parked?
    Mar 2012
    Quote Originally Posted by rhythmwhispers View Post
    impossible ata.. nakaground sa body yung negative terminal eh.. if you also put the positive sa body, puputok ang fuse.
car alarm that can detect somebody is touching your car (or scratching the paint)
