Results 1 to 10 of 10
    Sep 2005
    Hi guys, I just want to know how to distinguish between right hand drive lights from left hand drive ones. I am planning to change my Nissan B13 SS plastic lights, with glass ones. San maganda maghanap ng glass types if meron and how to know if pang left hand sya or right hand, madami kasi is from japan, which is right hand. I am checking out also ung mga Led types aftermarket if applicable sya or if may naka gawa na nun. Thank you in advance.
    Mar 2012
    Quote Originally Posted by dynamo1131 View Post
    I'm not familiar with your vehicle pero I do know that some headlights ay may marking sa HL assembly if it is RHD or LHD if walang mga markings then baka pwede mo ma ask ang shop owner to test fire the headlight. Point it on any flat surface. If ang step ng output is higher on the right that is LHD if it is higher on the left that is RHD.
    If the led bulbs you are planning to buy is not a direct replacement of you headlight assembly or specifically made for your HL assembly, better stay away from those. Yes maliwanag but kawawa ang kasalubong mo nyan since nag iba na ang light source(focal point) ng bulb mo so kahit naka low ka pa sabog pa rin output nyan.
    Quote Originally Posted by D3nb3r View Post
    Ang daming mga banong ganyan. Nakaka-yamot kapag nasalubong mo sa kalye,- ang sarap hagisan ng hollow blocks....
    Mar 2012
    yung iba they think they are cool dahil naka led sila at puti yung buga, yung iba naman misinformed lang and nagpa dala sa 100000000000000000000000000000 gazillion lumens na marketing without even thinking if proper ba installation or not. Also di din nila alam na yung mga 5500k and above na bulbs nila ay useless sa adverse weather condition lalo na sa wet asphalt road.
    Sep 2005
    faps hindi ung bulb tinutukoy ko, I am talking about ung assembly. Please see link below....
    http://www.ebay.com/itm/Sentra-B13-M...-/132137716487
    Mar 2012
    faps if yung bilog tinutukoy mo halo rings ang tawag dyan. Yes it can be integrated into any headlight with projectors and yes marami ng gumagawa nyan na mga retrofitter sa atin.
    Sep 2005
    thanks sa input faps..
How to distinguish B13 right hand Headlights in Surplus Shops
