Can someone explain what is retrofit,projector, hid on headlights? And where do you guys recommend me to have this job done?
Thanks in advance!
Thanks in advance!
Retrofit > the process of installing HID projectors inside your halogen stock headlights
Projector > the glass part that focuses the light coming from an HID bulb into an area on the road
HID > High Intensity Device, produces 3X more light than traditional halogen lighting setup
Main Parts of an HID system > Projector, HID Bulb, Ballast
where to go? depends on your location. andyan si garyq..
backread the following threads for more info:
http://tsikot.com/forums/car-lights-...hid-faq-20763/
http://tsikot.com/forums/car-lights-...-garyq-67675/]
This is right. If you want to install HID in your headlight, you should have it retrofitted with a projector. Pag HID lang hindi focused yung light so hindi mo ma maximize ang benifit. Plus you will annoy drivers on the opposite side of the road because you will be blinding them.
Maraming salamat sir red one and ambasador!
