Results 1 to 14 of 14
    Jun 2004
    Help!
    I'm going to replace the bulbs for my parking light since may kasama na bulb dun sa nabili ko na headlights.
    Problema ko ayaw matangal yung assembly, I followed the instructions pero ayaw talaga matanggal, both left and right.
    Attached yung picture nung assembly and yung instruction for the removal. Basically remove the screw and then pull forward. Ayaw! I tried checking for a second screw pero wala naman ako mahanap.
    Any Ideas?
    Sa Honda Accord pala yan.
    palagay ko napadikit na sa tagal. have you tried yanking it a bit?
    Jun 2005
    Quote Originally Posted by wildthing
    Try yanking it. Pag ayaw pa rin, break the glass (or plastic) then replace the bulb. - Joke only.
    Jan 2004
    Shake lang yan, then pull. The assembly only has a plastic hook holding it in the back, aside from the screw.
    May 2004
    Tama bro, konting shake & pukpok (kamay lang ha) lang yan. medyo nanikit na kaya ganyan.
    Minsan kailangan ng konting sampal niyan.
    May 2005
    sampal sampalin mo lang kabilaan ..
    baka nakatulog este nanikit dahil sa katagalan
    Jun 2004
    sobrang hirap talaga tanggalin, sa day off ko try ko ulit... kahit nung pinalitan yung headlight bulbs hirap na hirap sila, na stuck na rin sa tagal yung clips sa bulbs...
    May 2005
    sir Chris_d..
    try mo din spray ng penetrating oil (WD-40)...IMO
    Jun 2004
    Inisip ko rin gamitan ng WD-40, wala naman kayang effect kung malagyan yung mga electrical wiring?
    Sep 2005
    WD-40 on the edges and some yanking, then use the screwdriver as a lever to the screw mount to push out the assembly. You can also use a rubber grip (jar/bottle opener) with your other hand to pull it out at the same time. Good luck.
    May 2005
    Quote Originally Posted by chris_d
    Bro ..konti lang naman
    kung sa palagay mo nasobrahan ka ng spray ng WD-40...
    after mo nalinis or napalitan ng bulb ay Contact Cleaner naman apply mo sa socket or electrical wirings sa palagay mo inabot ng penetrating oil
    kaya niya dry ang penetrating oil..
    double check mo rin pala baka may clips or screw ka pa nakalimutan
    Jun 2004
    ic, thanks sa mga advice!
    Jun 2004
    Finally natanggal ko na yung assembly! Kelangan lang pala na medyo mas malakas yung sampal sa kanya... hehe
Parking Light Assembly removal
